Visual LISP, AutoLISP and General Customization
dmleves49
Message 1 of 11 (339 Views)
Accepted Solution
Custom Linetype - Shapes
339 Views, 10 Replies
07-26-2012 01:41 PM
Is it possible to create a linetype that just consists of the repeated shape? I'm trying to create railway tracks and my shape looks like this.
Shape
My linetype definition that ive tried is this:
*TRACK,Track
A,0.0001,-1.1622,[TRACK,Track.shx]
attempting to get a very small line, and then a space for my shape to fit into. This is what I get. Does anyone know the syntax to just include a repeating shape?
Dale
Line drawn using Linetype
*Expert Elite*
Kent1Cooper
Message 2 of 11 (334 Views)
Re: Custom Linetype - Shapes
07-26-2012 02:33 PM in reply to: dmleves49
dmleves49 wrote:
Is it possible to create a linetype that just consists of the repeated shape? ....
*TRACK,Track
attempting to get a very small line, and then a space for my shape to fit into. .... Does anyone know the syntax to just include a repeating shape?
Given the way your shape must be defined relative to its starting point, put the shape insertion part before the pen-up [negative-number] designation, rather than after.  You can't entirely eliminate the short continuous-line parts at the ends -- the best you can do is adjust the overall length to minimize them.
Kent Cooper
dmleves49
Message 3 of 11 (322 Views)
07-26-2012 11:39 PM in reply to: Kent1Cooper
Sorry If I'm not understanding your reply, but the shape cannot be the first spec. That was one of the first thing i tried. The Space can't be the initial spec either.
*Expert Elite*
Kent1Cooper
Message 4 of 11 (307 Views)
07-27-2012 04:58 AM in reply to: dmleves49
No, but it can be the second one rather than the third -- my suggestion was to put it before the pen-up designator, not before the initial pen-down designator:
A,0.0001,[TRACK,Track.shx],-1.1622
Kent Cooper
Distinguished Contributor
Message 5 of 11 (304 Views)
07-27-2012 05:29 AM in reply to: dmleves49
What a cool linetype.
However, I don't use linetypes that require SHX files. its just another thing that has to occompany your drawing when it shared. I have defined my linetypes to use the standard font. That way ALL users recieving my drawings can view them without the need of other files.
Here's my Vinyl Fence ... set your Standard Textstyle to Simplex with a 0.0 height for it to appear correctly.
*Fenceline_Vinyl,Fenceline Vinyl ____-____-____-____-____-___
A,0.250,-0.050,["|",STANDARD,S=0.0250,R=0.0,X=-0.050,Y=0.0083350],-0.0010,["_",STANDARD,S=0.10,R=0.0,X=-0.0510,Y=0.04770],0.0010,["|",STANDARD,S=0.0250,R=0.0,X=0.043250,Y=0.0083350],-0.044250,["_",STANDARD,S=0.10,R=0.0,X=-0.095250,Y=0.00952250],-0.0
For MY tracks ... I went in the field, took exact measurements and then created a dynamic block. Only drawback of a dynamic block (at least in version 2008), you can't make one to to work around an arc.
Autodesk Civil 3D 2014, Network, Carlson Software 2014, Build 121220
Windows 7 Pro, SP1 x64, AMD FirePro V4900 (FireGLV) (1920x1200)
Intel Core i7-3770 @ 3.4GHz, 8 GB RAM, 465GB WDC HD – 399GB free
dmleves49
Message 6 of 11 (292 Views)
07-27-2012 09:14 AM in reply to: dmleves49
Yes arcs are definitely a plus.:smileyhappy:
dmleves49
Message 7 of 11 (291 Views)
07-27-2012 09:19 AM in reply to: Kent1Cooper
That gives me a 'bad definition' error. Thanks for the suggestion though.
Message 8 of 11 (288 Views)
07-27-2012 09:27 AM in reply to: dmleves49
Hmm. It works great for me. You didn't by chance place it on three lines in the LIN file. It must be only two lines.
*Expert Elite*
Kent1Cooper
Message 9 of 11 (282 Views)
07-27-2012 10:40 AM in reply to: dmleves49
Well, I don't have any better ideas.  We have some that are defined just that way, and work well.
Kent Cooper
dmleves49
Message 10 of 11 (280 Views)
07-27-2012 10:58 AM in reply to: Kent1Cooper
I tried it again and of course it worked nicely. Thank you very much it looks much better. Due to the limitations of AutoCAD and the way they included the shape functionality I do have this problem in polylines where there is a vertex. (Line to Arc transition.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
