True. I thought maybe you saw something else happen once, and you started
using that way by default.
Thanks for the clarification Jason.
Tim
"A blind man lets nothing block his vision."
"Jason Piercey" wrote in message
news:5683671@discussion.autodesk.com...
On second look, I suppose the only difference is the trailing \\.
How important it is to the OP, I'm not sure.
Autodesk Discussion Group Facilitator
wrote in message news:5683648@discussion.autodesk.com...
Jason,
Is there a reason you add the 'vl-filename-directory'?
Command: (getvar "dwgprefix")
"C:\\Documents and Settings\\---\\My Documents\\"
Command: (vl-filename-directory (getvar "dwgprefix"))
"C:\\Documents and Settings\\---\\My Documents"
