Visual LISP, AutoLISP and General Customization
Cube unknown in lisp, but works from Command line ACAD2012
5 REPLIES 5
isbelldl
7291 Views, 5 Replies
I'm running AutoCAD 2012 (base version, but part of Mechanical install). Part of my .mnl file is set to run (command "cube" "off"). On one machine (Windows 7), it works fine. I'm temporarily on my laptop (Windows 8), & that portion no longer works.
If I type cube in the command line, it works fine. However, if I type (command "cube"), it says unknown command "CUBE".
Any ideas how to fix this?
5 REPLIES 5
mid-awe
in reply to: isbelldl
I have to use "navvcube" in lisp.
isbelldl
in reply to: mid-awe
Thanks, that was it. I'm still not sure why it worked on one machine considering that cube looks like it's just a shortcut for navvcube, but that seems to be the solution.
mid-awe
Glad that I could help. cheers.
dgorsman
Might be because CUBE is defined in the OOTB PGP file.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
mid-awe
in reply to: dgorsman
"Might be because CUBE is defined in the OOTB PGP file." - dgorsman
That explains his co-worker's lack of the issue.
”Boost
