Visual LISP, AutoLISP and General Customization
Creating an array using split function
4 REPLIES 4
zale-86
1150 Views, 4 Replies
In asp I'd write:
arrFileName = Split(DrawingName, "_")
JobNumber = arrFileName(0)
DrawingTitle = arrFileName(1)
SheetNumber = arrFileName(2)
I'd like to do the same thing in lsp. I don't want to be limited to three fields so the split function is perfect.
Is there an equilivant?
TIA
4 REPLIES 4
Kent1Cooper
in reply to: zale-86
@zale-86 wrote:
In asp I'd write:
I don't know asp, but if I'm interpreting what you want to do correctly....
There have been many threads here about splitting or subdividing text strings around designated delimiting characters, and put the sub-strings into a list.  You can search and find lots of others, but for instance, my Message 8 here:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Extract-a-folder-name-within-dwgprefi...
Load up the (sdtol) function, and do this with it:
(setq
  arrFileName (sdtol (getvar 'dwgname) "_")
  JobNumber (nth 0 arrFileName)
  DrawingTitle (nth 1 arrFileName)
  SheetNumber (nth 2 arrFileName)
...plus whatever other "fields" your drawing name has, separated by underscores.
You might also need to add something to whack the ".dwg" off the end of the drawing name, but first see whether it does what you want otherwise.
Kent Cooper, AIA
Command: (setq InfLst (ALE_String2List "JNumber_Title_SNumber" "_"))
("JNumber" "Title" "SNumber")
Command: (car InfLst)
"JNumber"
Command: (cadr InfLst)
"Title"
Command: (caddr InfLst)
"SNumber"
; Marc'Antonio Alessi, Italy - http://xoomer.virgilio.it/alessi
; Function: ALE_String2List
; Version 1.00 - November 2001
; Description:
;   convert a string into a list
; Arguments:
;   InpStr = string [STR]
;   CarDlm = delimiter [STR] 1 character
(defun ALE_String2List (InpStr CarDlm / SttPos EndPos TmpLst)
  (setq
    CarDlm (ascii CarDlm)   SttPos 0
    EndPos (vl-string-position CarDlm InpStr)
  (while EndPos
    (setq
      TmpLst (cons (substr InpStr (1+ SttPos) (- EndPos SttPos)) TmpLst)
      SttPos (1+ EndPos) EndPos (vl-string-position CarDlm InpStr SttPos)
  (reverse (cons (substr InpStr (1+ SttPos)) TmpLst))
; Function: ALE_String_ToList
; Version 1.00 - 01/2010
; Description:
;   convert a string into a list of strings
; Arguments:
;   TrueFl = if nil remove dupes delimiter
; Examples:
;  (ALE_String_ToList "aaa_vvv_hhh__yyy ___lll_" "_" T)
;  ("aaa" "vvv" "hhh" "" "yyy " "" "" "lll" "lll")
;  (ALE_String_ToList "aaa_vvv_hhh__yyy ___lll_" "_" nil)
;  ("aaa" "vvv" "hhh" "yyy " "lll")
(defun ALE_String_ToList (InpStr CarDlm TrueFl / SttPos EndPos TmpLst TmpStr)
  (setq
  (while EndPos
    (setq
      TmpStr (substr InpStr (1+ SttPos) (- EndPos SttPos))
    (and
      (or (/= TmpStr "") TrueFl)
      (setq TmpLst (cons TmpStr TmpLst))
  (if (or (/= (setq TmpStr (substr InpStr (1+ SttPos))) "") TrueFl)
    (reverse (cons TmpStr TmpLst))
    (reverse TmpLst)
zale-86
Perfect. Thanks a lot
microtecnologo
Hi Marc, I have tried your code and works perfectly, thanks a lot for sharing.
”Boost
