I found a program which rotates selected block(s) about thier insertion point. I modified it to rotate each of the block(s) about the y-axis. Works great. Now, I would like to change it so that it rotates a copy of each block about the y-axis and leaves the origial block in place. Its kind of like the mirror command exept it is rotating the new block(s) to the other side instead of flipping them. I want to keep all or the parameters of the block(s) the same as each original. I am using AutoCAD 2010. MOCORO is not recognized as a command. The new features workshop says to use the new command AMCOPYRM, which is not recognized either. Go figure.
(defun RotateDuplication (/ CN ENT theObjects SS)
(vl-load-com)
(setq SS (ssget (list (cons 0 "INSERT"))))
(repeat (setq CN (sslength SS))
(setq CN (1- CN)
ENT (ssname SS CN)
theObjects (vlax-ename->vla-object ENT)
(setq theAngle (vla-get-rotation theObjects))
(setq theAngle (+ theAngle pi))
(vla-put-rotation theObjects theAngle)
(setq
pt (vlax-safearray->list
(vlax-variant-value (vla-get-insertionpoint theObjects))
(vla-put-insertionPoint
theObjects
(vlax-3d-point (list (car pt) (* (cadr pt) -1) (caddr pt)))
) ; end repeat
(princ)
Little more persistance and I was able to figure it out. I forgot about the copy ability of the rotate command. Works like a charm! Sometimes relaying the problem helps to find a solution.
Thanks anyways,
(defun RotateDuplication ( / CN ENT theObjects SS)
(vl-load-com)
(setq SS (ssget (list (cons 0 "INSERT") ) ) )
(repeat (setq CN (sslength SS) )
(setq CN (1- CN)
ENT (ssname SS CN)
theObjects (vlax-ename->vla-object ENT) )
(setq pt (vlax-safearray->list (vlax-variant-value (vla-get-insertionpoint theObjects) ) ) )
(setq thept (list (car pt) (- (cadr pt) (cadr pt) ) (caddr pt) ) )
(vl-cmdf "rotate" ENT "" thept "c" 180)
); end repeat
(princ)
