Visual LISP, AutoLISP and General Customization
Convert to Multileader
12 REPLIES 12
Message 1 of 13
542 Views, 12 Replies
Has anyone done anything that allows one to convert a group of text objects and a leader line to the new AC2008 Multileader?
If someone has started something, then I don't need to reinvent the wheel? Otherwise I'll guess I'll try to invent a new wheel.
Thanks.
12 REPLIES 12
Message 2 of 13
I resorted to VBA. Here's what I've got so far, if anyone cares....
Message 3 of 13
Allen,
I have to plead complete ignorance when it comes to VBA. Any chance you
could convert to VLISP for us, or at least explain how to load this?
Dan
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
http://partnerproducts.autodesk.com/popups/company.asp?rdid=2139
"Allen Johnson" wrote in message
news:5533546@discussion.autodesk.com...
Message 4 of 13
i loaded it but can't seem to run it. what is the macro name?daniel put the file in your search path then type vbaload find the file and load it. then add this to your startup suite so it will load everytime you open. to run it type -vbarun then the macro name which we need to get from allen. you can put this into a button and add to a toolbar
Message 5 of 13
I meant ask how to run it. I can load it also, but can't run the macro.
wrote in message news:5536757@discussion.autodesk.com...
Message 6 of 13
I've been working on it but found some issues. See the autodesk.autocad.customization.vba newgroup topic "Multileader code appears
to create a corrupt drawing"
http://discussion.autodesk.com/thread.jspa?threadID=557485
Message 7 of 13
the macro is usually the text after the sub like updateattribute would be the macro in this example
Public Sub Updateattribute()
i see a cml and makemleader but neither work hmmmm
Message 8 of 13
CML works, but it expects there to be a previous selection set. Just select
the group containing the leader & text, initiate the Move command, and ESC.
Now try to run CML.
wrote in message news:5536886@discussion.autodesk.com...
Message 9 of 13
Or use the select command to select the objects, then start CML.
"Jeff Mishler" wrote in message news:5536935@discussion.autodesk.com...
Now try to run CML.
Message 10 of 13
This is what I'm using. It assumes that you have group selection on and that you define the "VBAPath" variable as the path to the
dvb file.
(defun C:MM ()
(command "select" "si" pause)
(vl-vbarun (strcat VBAPath "ConvertMleader.dvb!modCML.CML"))
(princ)
Message 11 of 13
ok i tried all of the methods discussed and it doesn't say macro not found but it does not convert to mleader either?
Message 12 of 13
See this link for a more up to date program
Message 13 of 13
See this link for a more up to date program.
”Boost
