Convert VIEWPORT to polyline
jfrog
Message 1 of 20
jfrog
Does anyone have any routines to convert a viewport in paperspace to a polyline viewport? (without changing the current view)
I'd like to be able to add vertices to the viewports, which you can do if it's a pline.
Thanks in advance
Replies (19)
Message 2 of 20
jfrog
BTW, I'm using Acad 2002, if that matters
Message 3 of 20
One way of doing this would be to go inside the Viewport you have now and
use the VIEW command to save the current view.
Then back in Pspace, create your new polygonal shape with your PLINE, then
use MVIEW's OBJECT option to convert your newly drawn polygon into a Pspace
Viewport.
Then go inside this new Viewport and use the VIEW command to restore the
previous view you saved.
Paul
wrote in message news:5840018@discussion.autodesk.com...
Message 4 of 20
jfrog
Brilliant in it's simplicity....thanks much!
Message 5 of 20
joshc96
The attached is kinda messy, completely undocumented and works on viewports
and polyline-viewports only....but it works.
Josh
-Josh
Message 6 of 20
jfrog
thanks...this routine appears to create a pline in model space to correlate to the mview, right? Not quite what I was looking for, but it does do something I normally do manually...so I'll use it anyway.
What I was looking for was a routine to convert the paperspace viewport (created my the MVIEW command) to a polyline viewport (as created by the MVIEW command, "Polygonal" option)
Thanks again,
John
Message 7 of 20
VPCLIP
Message 8 of 20
paullimapa
Great suggestion @Anonymous
VPCLIP works as long as you retrace the rectangular Vport corners and then you'll end up with a Polyline Vport.
Now if there was a lisp routine that can do this automatically...
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 9 of 20
I prefer VPCLIP
Message 10 of 20
Deirdre.Warner
Observer
Observer
Just used this option and it worked great! Huge time saver!
Message 11 of 20
nodink
Here is what I'd do.. No LSP routine/VPCLIP needed.  Just rotate the viewport 1 degree and rotate back 1 degree. Voila, your VP is now a Polyline. BUT before rotate it back 1degree, Pedit it before rotate it back.
Message 12 of 20
USE BOUNDARY COMMAND
Message 13 of 20
Patricia_Villar-HPA
Thanks Carlos, this is the answer. Easy and fast!
Message 14 of 20
HN_arucker
3yrs later and still an effective answer. Thanks Much!
Message 15 of 20
Brilliant! That's my learning quota for the day. In danger of exceeding said quota however, why Pedit before rotating it back?
Message 16 of 20
HN_arucker
If you just rotate it back then, for me, it turns back to a normal VP. Where as if you run the PEDIT command, it will remain a polyline. You can also just add a vertex instead of PEDIT and that will also give the desired results; and it wont let you use PEDIT or add a vertex before rotating.
Message 17 of 20
thaddeus.morrison
I logged into my account just to give this a thumbs up. This is the epitome of KISS.
Message 18 of 20
hani.serhan
Observer
Observer
VPClip!
Message 19 of 20
jeadeAY9W4
Observer
Observer
this is better than VPCLIP imo....cool
Message 20 of 20
geronimo100000000
Community Visitor
Community Visitor
fecha 18/11/2025
el rotar un viewport y luego volver a rotar a su posicion inicial aplicando el PEDIT, a la fecha sigue funcionanado, gracias por compartir el conocimiento
