Member
twlincoln2009
Message 21 of 23 (377 Views)
Re: Convert Field to Text
12-13-2012 05:24 PM in reply to: Ian_Bryant
This is an old post, so I hope Ian (or someone else can help) I am looking to remove FIELD definitions from MTEXT within a TABLE... similar to the code listed above (as all the above works with DIMS, TEXT, MTEXT, ATTRIBUTES, but not TABLES. :-(
Thanks in advance. - Tracy Lincoln (yes, the one and only)
Valued Mentor
Ian_Bryant
Message 22 of 23 (357 Views)
12-14-2012 04:09 AM in reply to: twlincoln2009
not well tested,
and will not change tables on locked layers,
or change locked table cells.
Create a selection set of the table entities
and step through it applying the following function
to each ename in the set.
(defun do_table (ent / obj nr nc nc1 nr1 vv tstring)
 (setq obj (vlax-ename->vla-object ent)
       nr (vlax-get obj 'Rows)
       nc (vlax-get obj 'Columns)
 (setq nr1 0)
 (while (< nr1 nr)
   (setq nc1 0)
   (while (< nc1 nc)
     (if (and
            (= (vla-GetCellType obj nr1 nc1) 1)
            (setq tstring (vla-gettext obj nr1 nc1))
         (progn
          (vl-catch-all-apply 'vla-deletecellcontent
                 (list obj nr1 nc1)
          (setq vv (vla-getcellvalue obj nr1 nc1))
          (vl-catch-all-apply 'vla-SetTextString
                 (list obj nr1 nc1 vv tstring)
     (setq nc1 (+ 1 nc1))
   (setq nr1 (+ 1 nr1))
 (princ)
Ian
Member
twlincoln2009
Message 23 of 23 (275 Views)
01-16-2013 12:17 PM in reply to: Ian_Bryant
Thank you for the code, but I cannot seem to get it to work after I load it?
You are not logged in.
Ask the Community
