• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    New Member
    MontgomeryRoth
    Convert Attribute Tag Into Attribute Value
    219 Views, 3 Replies
    12-08-2011 01:38 PM
    AutoLISP Experience: Minimal
    Background: Someone exploded an attribute block and copied it hundreds of times throughout a project, each time changing the Attribute Tag to match the Value they expected to appear in their drawing.  The drawing must be xrefed, so the attribute definitions do not appear.
    (There is only 1 attribute in the block.)
    Proposed Solutions:
    1:AutoLISP routine which copies Tag data from Attribute Definition into Value of Attribute Block:
    Prompt-Select Attribute Definition
    Copy Tag data
    Prompt-Select Attribute Block
    Paste data into Value
    (Allow repeat to speed workflow)(*PREFERRED*)
    2:AutoLISP routine which copies Tag data from Attribute Definition into Default Value and creates a new Block:
    Copy Tag data
    Paste data into Default Value
    Create New Block
    (Select Multiple Objects)(Creates tons of new blocks which are messy)
    Please use plain text.
    Valued Mentor
    _Tharwat
    Re: Convert Attribute Tag Into Attribute Value
    12-08-2011 01:54 PM in reply to: MontgomeryRoth
    This would help you with the first part of your request ...
    (defun c:TesT (/ attributeDefinition attent ss i n e)
      ;; Tharwat 08. Dec. 2011 ;;
      (if
        (and (setq attributeDefinition
                    (car
                      (entsel "\n Select Attribute definition :"
             (eq (cdr (assoc 0 (setq attent (entget attributeDefinition))))
                 "ATTDEF"
             (progn (prompt "\n Select Attributed Blocks ")
                    (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1))))
         (repeat (setq i (sslength ss))
           (setq n (entnext (ssname ss (setq i (1- i)))))
           (while
             (not
               (eq (cdr (assoc 0 (setq e (entget n))))
                   "SEQEND"
              (entmod
                (subst (cons 1 (cdr (assoc 2 attent))) (assoc 1 e) e)
              (setq n (entnext n))
      (princ)
    New Member
    MontgomeryRoth
    12-08-2011 04:42 PM in reply to: _Tharwat
    Thanks so much, this worked great!
    You probably cut our repair time down to a quarter of what it would have been or better.
    Exactly what we were looking for.
    Valued Mentor
    _Tharwat
    12-09-2011 01:22 AM in reply to: MontgomeryRoth
    You're welcome . :smileyhappy:
    I am glad to hear that .
