Visual LISP, AutoLISP and General Customization
Connot use $ sign in MENU text
2 REPLIES 2
BIMologist_
126 Views, 2 Replies
I have a lisp function which I need to PASS a $ sign in the text, could not figure out how to do it as $ is a menu special char.
^C^C(nm_hatchplines "SOLID" "OFC$HL" "OFC$" 32)
It bombs due to $ sign, I can always wrap it in a command as below and then call the command from the menu, but it makes it non dynamic and when they have to add a new set of HATCHING I get a call for. I cannot get rid of $ sign since ARCHIBUS loves them to the heart , so have to have them there/.
thanks
(defun C:HATCHOFC ( / HatchPattern HatchLayer PlineLayer HatchLayerColor )
;setup the variables here
(setq
HatchPattern "SOLID"
HatchLayer "OFC$HL"
PlineLayer "OFC$"
HatchLayerColor 32
(nm_hatchplines HatchPattern HatchLayer PlineLayer HatchLayerColor)
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
2 REPLIES 2
Ian_Bryant
in reply to: BIMologist_
Try
^C^C(nm_hatchplines "SOLID" (strcat "OFC" (chr 36) "HL") (strcat "OFC" (chr 36)) 32)
Regards Ian
BIMologist_
Works like a CHARM
thanks
”Boost
