lisp working fine
Thanks...
If it will give reports for the mismatch it will rocks..
How about the free DWG Compare app on the Autodesk Exchange Store:
https://apps.autodesk.com/ECSCAD/en/Detail/Index?id=136068404068200943&appLang=en&os=Win32_64
Area Object Link |
Attribute Modifier |
Dwg Setup |
Feet-Inch Calculator
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
FYI, that plugin from AppStore is bad... After installation which is successful and upon starting ACAD, CAD reports missing *.dll... I can't recall correctly what dll is an issue, but it's something that installation should have provided - something like missing CompareDWG???.dll in alert box, after which you can only terminate CAD, and start again *.msi file to uninstall it... Good god that I haven't permanently corrupted CAD because of this...
That's a strange error because I've had no problems installing or running the app afterwards. Perhaps you should email them AutoCAD.apps@autodesk.com to let them help you troubleshoot this problem?
Area Object Link |
Dwg Setup |
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
