Solved by hmsilva. Go to Solution.
One way
(setq ss (ssadd)
obj (entlast))
("_your divide command")
(while (setq obj (entnext obj))
(ssadd obj ss)
(if ss
(repeat (setq i (sslength ss))
(setq hnd (ssname ss (setq i (1- i)))
obj (vlax-ename->vla-object hnd)
(vla-put-XScaleFactor obj 1.0)
(vla-put-YScaleFactor obj 1.0)
(vla-put-ZScaleFactor obj 1.0)
HTH
Henrique
@gustavobernardi wrote:
Hy guys I have a lisp to subdivide a object with specific block. The block has created in centimeter units, if I insert in a file with the same units works but if the file is set in Meters units the command DIVIDE automatically aply a scale of 100 in my block and is not the result I want. how to select all blocks created during the divide and set your scales to 1,1,1 (XYZ) Excuse me if I was not clear. Thanks
You can use the DIV+ command defined in the attached DivideMeasurePlus.lsp routine, which has many enhancements compared to the native Divide [and Measure, in the case of MEA+] command [see the top of the file]. One is that you can specify whatever Scale you want for Blocks [when that's what you choose to Divide or Measure with].
