Visual LISP, AutoLISP and General Customization
ssexton
Message 1 of 12 (339 Views)
Accepted Solution
Combining Strings
339 Views, 11 Replies
05-16-2012 07:52 AM
I'm trying to combine two user inputs and a constant with setq without spaces so I can use it in an AutoCAD command.
I haven't seen a string command that does this. It always has spaces in between the fetched valvues.
Thanks for any help
*Expert Elite*
hmsilva
Message 2 of 12 (334 Views)
Re: Combining Strings
05-16-2012 08:10 AM in reply to: ssexton
Try
(setq newstring (vl-list->string (vl-remove 32 (vl-string->list yourstring))))
Cheers
Henrique
*Expert Elite*
Kent1Cooper
Message 3 of 12 (329 Views)
05-16-2012 08:28 AM in reply to: ssexton
Thanks for any help
I wonder how you're doing it.  For me, it doesn't do that if I don't include spaces in what I enter for the User inputs [a2 is the 'constant' in this case]:
Command: (setq a1 (getstring))
What <--- typed in
"What"
Command: (setq a2 "The" a3 (getstring))
Heck <--- typed in
"Heck"
Command: (strcat a1 a2 a3)
"WhatTheHeck"
Am I misunderstanding the problem?  Am I at least correct that you want to put strings together without spaces in the first place, rather than remove spaces from the result after the fact, as others' suggestions are designed to do?
Kent Cooper
Valued Mentor
gasty1001
Message 4 of 12 (326 Views)
05-16-2012 08:33 AM in reply to: ssexton
Not sure, but somthing like: (vl-remove-if (function (lambda(x)(= x 32)) (vl-string->list MyString)) will remove the spaces from a string, and (vl-list->string listOfChar) will concatenate back the list.
You can put that on a function:
(defun StripOutBlanks(MyString)
    (vl-list->string (vl-remove-if
     (function
      (lambda(x)(= x 32)))
use: (StripOutBlanks "Hi There")
return: "HiThere"
Gaston Nunez
ssexton
Message 5 of 12 (318 Views)
05-16-2012 09:03 AM in reply to: ssexton
Thanks everyone for the solutions!!
ssexton
Message 6 of 12 (258 Views)
05-23-2012 07:42 AM in reply to: Kent1Cooper
This worked well. Thanks!
But the insert command wont accept "0,0" as an input. I've also tried:
(setq d1 '(0 0))  and set d1 in the command line for coordinate input but AutoCAD wont accept either.
ideas?
*Expert Elite*
hmsilva
Message 7 of 12 (248 Views)
05-23-2012 07:58 AM in reply to: ssexton
ssexton,
can you  post some of your code, so I can see where it gives error...
ssexton
Message 8 of 12 (242 Views)
05-23-2012 08:03 AM in reply to: hmsilva
This is the code line:
(setq e (strcat a b aa))
 (command "insert" e "" "0,0" "" "" "" "")
This is the reply I get:
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]:
Point or option keyword required.
; error: Function cancelled
*Expert Elite*
hmsilva
Message 9 of 12 (240 Views)
05-23-2012 08:09 AM in reply to: ssexton
Try
 (command "insert" e "0,0" "" "" "" "")
Cheers
Henrique
*Expert Elite*
Kent1Cooper
Message 10 of 12 (236 Views)
05-23-2012 08:25 AM in reply to: ssexton
As hmsilva suggested, you don't want that Enter [""] between the Block name and the insertion point.  [It's not like object selection in an editing command, where you need to tell it you're done selecting -- you can't Insert more than one Block name at a time.]
Also, I think you have more Enters at the end than you need, unless maybe the Block includes an Attribute that you want to accept a default value for, and you have ATTDIA set to 0.  And unless you need to have it saved for some later use, the Block name could just be "built" right inside the Insert command, with no need for the 'e' variable:
(command "insert" (strcat a b aa) "0,0" "" "" "")
Kent Cooper
You are not logged in.
Announcements
Need installation help?
Ask the Community
