Visual LISP, AutoLISP and General Customization
Combining Strings
11 REPLIES 11
Message 1 of 12
ssexton
1190 Views, 11 Replies
Combining Strings
I'm trying to combine two user inputs and a constant with setq without spaces so I can use it in an AutoCAD command.
I haven't seen a string command that does this. It always has spaces in between the fetched valvues.
Thanks for any help
11 REPLIES 11
Message 2 of 12
hmsilva
in reply to: ssexton
Try
(setq newstring (vl-list->string (vl-remove 32 (vl-string->list yourstring))))
Cheers
Henrique
Message 3 of 12
Kent1Cooper
Thanks for any help
I wonder how you're doing it.  For me, it doesn't do that if I don't include spaces in what I enter for the User inputs [a2 is the 'constant' in this case]:
Command: (setq a1 (getstring))
What <--- typed in
"What"
Command: (setq a2 "The" a3 (getstring))
Heck <--- typed in
"Heck"
Command: (strcat a1 a2 a3)
"WhatTheHeck"
Am I misunderstanding the problem?  Am I at least correct that you want to put strings together without spaces in the first place, rather than remove spaces from the result after the fact, as others' suggestions are designed to do?
Kent Cooper, AIA
Message 4 of 12
hgasty1001
Not sure, but somthing like: (vl-remove-if (function (lambda(x)(= x 32)) (vl-string->list MyString)) will remove the spaces from a string, and (vl-list->string listOfChar) will concatenate back the list.
You can put that on a function:
(defun StripOutBlanks(MyString)
    (vl-list->string (vl-remove-if
     (function
      (lambda(x)(= x 32)))
use: (StripOutBlanks "Hi There")
return: "HiThere"
Gaston Nunez
Message 5 of 12
ssexton
Thanks everyone for the solutions!!
Message 6 of 12
ssexton
in reply to: Kent1Cooper
This worked well. Thanks!
But the insert command wont accept "0,0" as an input. I've also tried:
(setq d1 '(0 0))  and set d1 in the command line for coordinate input but AutoCAD wont accept either.
ideas?
Message 7 of 12
hmsilva
ssexton,
can you  post some of your code, so I can see where it gives error...
Message 8 of 12
ssexton
in reply to: hmsilva
This is the code line:
(setq e (strcat a b aa))
 (command "insert" e "" "0,0" "" "" "" "")
This is the reply I get:
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]:
Point or option keyword required.
; error: Function cancelled
Message 9 of 12
hmsilva
Try
 (command "insert" e "0,0" "" "" "" "")
Cheers
Henrique
Message 10 of 12
Kent1Cooper
As hmsilva suggested, you don't want that Enter [""] between the Block name and the insertion point.  [It's not like object selection in an editing command, where you need to tell it you're done selecting -- you can't Insert more than one Block name at a time.]
Also, I think you have more Enters at the end than you need, unless maybe the Block includes an Attribute that you want to accept a default value for, and you have ATTDIA set to 0.  And unless you need to have it saved for some later use, the Block name could just be "built" right inside the Insert command, with no need for the 'e' variable:
(command "insert" (strcat a b aa) "0,0" "" "" "")
Kent Cooper, AIA
Message 11 of 12
ssexton
I appreciate everyone's help. This is going to automate some things for us!
Message 12 of 12
hmsilva
You're welcome, ssexton.
”Boost
