wondering, why this won't work, when selcting xref to clip, I get 'non found'
(defun c:c4 ()
(command "clip" pause "n" "y" "p" pause pause pause "")
(princ)
When I run it, I get this:
Command: C4
clip
"CLIP" Select Object to clip: 1 found
Enter clipping option
[ON/OFF/Clipdepth/Delete/generate Polyline/New boundary] <New>: n Outside mode - Objects outside boundary will be hidden.
Specify clipping boundary or select invert option:
[Select polyline/Polygonal/Rectangular/Invert clip] <Rectangular>: y
Invalid option keyword.
; error: Function cancelled
What is the "Y" a response to on your end?
Acad CLIP seems to differ on apps, I use Civil 3d 2014.
Without the lisp:
Command: CLIP
[ON/OFF/Clipdepth/Delete/generate Polyline/New boundary] <New>: N
Delete old boundary(s)? [Yes/No] <Yes>: Y
[Select polyline/Polygonal/Rectangular/Invert clip] <Rectangular>: P
With the lisp:
Command: c4
clip Select Object to clip:
Select objects: n
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle
In case (command "clip" pause "" "n" "y" "p" pause pause pause "")
I get:
Command: C4 clip Select Object to clip:
Select objects:
None found.
Command: n Unknown command "N". Press F1 for help.
Command: y Unknown command "Y". Press F1 for help.
Command: p Unknown command "P". Press F1 for help.
ok, thank you for cehecking this out!
@rkmcswain wrote:
Ah. Then you should probably accommodate for the instances where there is no existing boundaries, unless this is a specific routine only used where there will be one.
