Visual LISP, AutoLISP and General Customization
Clipping lisp
8 REPLIES 8
Message 1 of 9
robert06
1746 Views, 8 Replies
Clipping lisp
wondering, why this won't work, when selcting xref to clip, I get 'non found'
(defun c:c4 ()
    (command "clip" pause "n" "y" "p" pause pause pause "")
    (princ)
8 REPLIES 8
Message 2 of 9
rkmcswain
in reply to: robert06
When I run it, I get this:
Command: C4
clip
"CLIP" Select Object to clip: 1 found
Enter clipping option
[ON/OFF/Clipdepth/Delete/generate Polyline/New boundary] <New>: n Outside mode - Objects outside boundary will be hidden.
Specify clipping boundary or select invert option:
[Select polyline/Polygonal/Rectangular/Invert clip] <Rectangular>: y
Invalid option keyword.
; error: Function cancelled
 What is the "Y" a response to on your end?
Message 3 of 9
robert06
in reply to: rkmcswain
Delete old boundaries: Yes
Message 4 of 9
hmsilva
Try
(defun c:c4 ()
    (command "_.xclip" pause "" "n" "y" "p" pause pause pause "")
    (princ)
HTH
Henrique
Message 5 of 9
robert06
Acad CLIP seems to differ on apps, I use Civil 3d 2014.
Without the lisp:
Command: CLIP
[ON/OFF/Clipdepth/Delete/generate Polyline/New boundary] <New>: N
Delete old boundary(s)? [Yes/No] <Yes>: Y
[Select polyline/Polygonal/Rectangular/Invert clip] <Rectangular>: P
With the lisp:
Command: c4
clip Select Object to clip:
Select objects: n
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle
In case (command "clip" pause "" "n" "y" "p" pause pause pause "")
I get:
Command: C4 clip Select Object to clip:
Select objects:
None found.
Command: n Unknown command "N". Press F1 for help.
Command: y Unknown command "Y". Press F1 for help.
Command: p Unknown command "P". Press F1 for help.
Message 6 of 9
robert06
in reply to: hmsilva
with this change it worked "_xclip" not "_.xclip"
thank you!
@hmsilva wrote:
Try
(defun c:c4 ()
    (princ)
HTH
Henrique
Message 7 of 9
hmsilva
You're welcome, Robert
Should work with "_.xclip"...
Henrique
Message 8 of 9
rkmcswain
Ah. Then you should probably accommodate for the instances where there is no existing boundaries, unless this is a specific routine only used where there will be one.
Message 9 of 9
robert06
ok, thank you for cehecking this out!
”Boost
