Visual LISP, AutoLISP and General Customization
Clear the "Previous" selection set
18 REPLIES 18
Message 1 of 19
355 Views, 18 Replies
I thought this was posted here, but I can't seem to find any trace.
Is there a way to clear the previous selection set without using the (command) function?
John Uhden, Cadlantic/formerly CADvantage
[ mailto:juhden@cadlantic.com ]
[ http://www.cadlantic.com ]
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
18 REPLIES 18
Message 2 of 19
Hi John,
I belive that solution I saw was to create a dummy point, then entdel.
-Jason
Member of the Autodesk Discussion Forum Moderator Program
"John Uhden" wrote in message
news:BE6677E7C9AAFA4D5CB06228D7BE0C90@in.WebX.maYIadrTaRb...
(command) function?
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
Message 3 of 19
Hmmm. guess I should have tried that first....
-Jason
Message 4 of 19
You were close:
Command: select
Select objects: Specify opposite corner: 3 found
Select objects:
Command: (command "._point" "0,0" "._erase" (entlast) "")
._point
Current point modes: PDMODE=0 PDSIZE=0.0000
Specify a point: 0,0
Command: ._erase
Select objects: 1 found
Select objects:
Command: nil
Command: (ssget "P")
nil
I found that above tidbit in a post from Jim Claypool.
R. Robert Bell, MCSE
www.AcadX.com
"Jason Piercey" wrote in message
news:3CC8BE3EC78C46DC5B7117FFAF1A1475@in.WebX.maYIadrTaRb...
> -Jason
Message 5 of 19
John:
I believe any call to (ssget) sets the previous selection to the result.
Judicious use of (sssetfirst) and (ssget "I") might work. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Message 6 of 19
Beautiful Owen!
Command: select
Select objects:
Command: (sssetfirst nil nil)
(nil nil)
Command: (ssget "I")
nil
www.AcadX.com
"Owen Wengerd" wrote in message
news:22CA0466C61C87C240623B00AD2D13A5@in.WebX.maYIadrTaRb...
> John:
> Owen Wengerd
Message 7 of 19
You didn't go far enough...
Command: select
Select objects:
(nil nil)
Command: (setq ss (ssget "I"))
nil
Command: select
Select objects: p
3 found
Select objects: *Cancel*
I know that (command "_.erase") etc. will do the trick, but the challenge is to NOT use (command).
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"R. Robert Bell" wrote in message news:5BB3F6FC814A07CE382394DA3B5AC069@in.WebX.maYIadrTaRb...
> Beautiful Owen!
> Command: select
> Select objects:
> (nil nil)
> nil
> www.AcadX.com
> > John:
> > Owen Wengerd
Message 8 of 19
I would have thought this would work, and indeed ActiveSelectionSet.Count is
0, but an (ssget "P") returns the old previous...
(vla-Clear (vla-Get-ActiveSelectionSet
(vla-Get-ActiveDocument (vlax-Get-Acad-Object))))
www.AcadX.com
news:7625913686310A4E224A64391BC41F65@in.WebX.maYIadrTaRb...
> Command: select
> Select objects:
> (nil nil)
> nil
> Command: select
> Select objects: p
> 3 found
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
> > Beautiful Owen!
> > Command: select
> > Select objects:
> > (nil nil)
> > nil
> > www.AcadX.com
> > > John:
result.
> > > Owen Wengerd
Message 9 of 19
What is the big hang up on using (command) to accomplish a task that
otherwise might take forever to figure out?
Am I missing something? I like challenges as much as anybody, but sometimes
I see it here as an obsession.
> Command: select
> Select objects:
> (nil nil)
> nil
> Command: select
> Select objects: p
> 3 found
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
> > Beautiful Owen!
> > Command: select
> > Select objects:
> > (nil nil)
> > nil
> > www.AcadX.com
> > > John:
result.
> > > Owen Wengerd
Message 10 of 19
Maybe for the use with a reactor, where (command) is not allowed? Just
guessing....
-Jason
Message 11 of 19
Sorry I didn't explain. The reason is for transparency.
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Jim Claypool" wrote in message news:6A8A11E7DD0A8414EDF01189A2F93E52@in.WebX.maYIadrTaRb...
> > Command: select
> > Select objects:
> > (nil nil)
> > nil
> > Command: select
> > Select objects: p
> > 3 found
> > 2 Village Road
> > Sea Girt, NJ 08750
> > Tel. 732-974-1711
> > > Beautiful Owen!
> > > Command: select
> > > Select objects:
> > > (nil nil)
> > > nil
> > > www.AcadX.com
> > > > John:
> result.
> > > > Owen Wengerd
Message 12 of 19
(command ".point" "0,0")(command ".erase" (entlast) "")(princ)
is transparent if cmdecho is 0
news:757EE0CC1F122D582382DF4E8431B34B@in.WebX.maYIadrTaRb...
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
sometimes
> > > Command: select
> > > Select objects:
> > > (nil nil)
> > > nil
> > > Command: select
> > > Select objects: p
> > > 3 found
challenge
> > > 2 Village Road
> > > Sea Girt, NJ 08750
> > > Tel. 732-974-1711
> > > > Beautiful Owen!
> > > > Command: select
> > > > Select objects:
> > > > (nil nil)
> > > > nil
> > > > www.AcadX.com
> > > > > John:
> > result.
> > > > > Owen Wengerd
Message 13 of 19
Command: Erase
Select object: '(noP)
www.AcadX.com
news:67A7208BC75834E1ED6401D71C4E3BED@in.WebX.maYIadrTaRb...
> > 2 Village Road
> > Sea Girt, NJ 08750
> > Tel. 732-974-1711
> sometimes
> > > > Command: select
> > > > Select objects:
> > > > (nil nil)
> > > > nil
> > > > Command: select
> > > > Select objects: p
> > > > 3 found
> challenge
> > > > 2 Village Road
> > > > Sea Girt, NJ 08750
> > > > Tel. 732-974-1711
> > > > > Beautiful Owen!
> > > > > Command: select
> > > > > Select objects:
> > > > > (nil nil)
> > > > > nil
> > > > > www.AcadX.com
> > > > > > John:
the
> > > result.
> > > > > > Owen Wengerd
Message 14 of 19
How does turning off CmdEcho make it transparent?
-Jason
Message 15 of 19
This works, but still shows a previous selection set even though there is
none:
(if (entmake (entget (ssname (ssget "L") 0)))
(entdel (ssname (ssget "L") 0))
Command: (if (entmake (entget (ssname (ssget "L") 0)))
(_> (entdel (ssname (ssget "L") 0))
(_> )
Command: _select
Select objects: _p 1 found
Select objects:
Command:
Eric S.
A2k/W2k
Message 16 of 19
Robert:
After stumbling around, I tripped over the Express Tools' (acet-ss-clear-prev) function which does the trick. By testing, I found that it's in the file Aecutil.fas but unfortunately it's not transparent. In fact it's using the good ol' make/erase method. Observe...
Enter new value for CMDECHO <1>:
Command: (acet-ss-clear-prev)
_.select
Select objects: 1 found, 1 total
1 was not in current space.
Select objects:
Command: _.undo Enter the number of operations to undo or
[Auto/Control/BEgin/End/Mark/Back] <1>: 1 .SELECT GROUP
Command: nil
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"R. Robert Bell" wrote in message news:71457C465FBC3EAF30B556F4E5421701@in.WebX.maYIadrTaRb...
> Command: Erase
> www.AcadX.com
> > > 2 Village Road
> > > Sea Girt, NJ 08750
> > > Tel. 732-974-1711
> > sometimes
> > > > > Command: select
> > > > > Select objects:
> > > > > (nil nil)
> > > > > nil
> > > > > Command: select
> > > > > Select objects: p
> > > > > 3 found
> > challenge
> > > > > 2 Village Road
> > > > > Sea Girt, NJ 08750
> > > > > Tel. 732-974-1711
> > > > > > Beautiful Owen!
> > > > > > Command: select
> > > > > > Select objects:
> > > > > > (nil nil)
> > > > > > nil
> > > > > > www.AcadX.com
> > > > > > > John:
> the
> > > > result.
> > > > > > > Owen Wengerd
Message 17 of 19
I had stumbled on that kind of method too. With locked layer checking, that's the best I think we're gonna do. Thanks much, Eric.
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Eric Schneider" wrote in message news:4121AA0DDF961E55E279C97A116FDE1E@in.WebX.maYIadrTaRb...
> none:
> (_> )
> Command: _select
> Select objects:
> Command:
> Regards,
> Eric S.
> A2k/W2k
Message 18 of 19
Adding the locked layer checking, here's the deal. Feel free to make it better. Thank you all for the help.
(defun @cv_ss_clear ( / dummy layer flag flag!)
(setq dummy (entmakex '((0 . "POINT")(8 . "0")(10 0 0 0)(60 . 1)))
layer (entget (tblobjname "layer" "0"))
flag (assoc 70 layer)
flag! (cons 70 (boole 2 (cdr flag) 4))
(entmod (subst flag! flag layer))
(entdel (ssname (ssget "X" '((0 . "POINT")(8 . "0")(10 0 0 0)(60 . 1))) 0))
(entmod (subst flag flag! layer))
(gc)
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
> none:
> (_> )
> Command: _select
> Select objects:
> Command:
> Regards,
> Eric S.
> A2k/W2k
Message 19 of 19
John:
Yup, it looks like (ssget) only sets the previous set if it actually
returns something. Bummer. 😞
Owen Wengerd
”Boost
