Visual LISP, AutoLISP and General Customization
Circle to lwpline problems
7 REPLIES 7
Message 1 of 8
274 Views, 7 Replies
I am trying to convert a circle entity to a lwpline entity so it may be used
by a routine that only likes plines...I am having problems converting from
the circle information to lwpline information. My script takes a circle and
converts it to an lwpline...anyone know where im going wrong? It works
sometimes but alot of the time it just gives me odd shaped arcs.
(edata holds a circle entity, ename holds the entity name)
(setq cenPt (getdxf 10 edata))
;get centerpoint
(setq rad (getdxf 40 edata))
;get radius
(setq startPt (polar cenPt 0 rad))
;get the point at 0 degrees
(setq endPt (polar cenPt pi rad))
;get the point at 180 degrees
(command "pline" startPt "a" "ce" cenPt endPt "")
;draw a pline from 0 degrees to 180 degrees
(setq ent1 (entlast))
;get our newly created entity for later join to ent2
(command "pline" endPt "a" "ce" cenPt startPt "")
;draw a pline from 180 degrees to 0 degrees
(setq ent2 (entlast))
;get our newly created entity for later join to ent1
(command "pedit" ent1 "j" ent2 "" "")
;join ent1 and ent2 to create our new "pline-circle"
(entdel ename)
;get rid of the original circle
(defun getdxf (dxfcode ent)
(cdr (assoc dxfcode ent))
All suggestions are appreciated.
Mike Krous
7 REPLIES 7
Message 2 of 8
Here is one that I wrote a couple of years ago.
-Jason
Member of the Autodesk Discussion Forum Moderator Program
"Mike Krous" wrote in message
news:481562ECCE908A2CE13124B7FE45E8C4@in.WebX.maYIadrTaRb...
Message 3 of 8
Hi Mike,
I'm lazy and like sweets. Therefore DONUTs mustn't be ignored 😉
;circle 2 pline - ruul 03/09/11
(defun c:c2p ( / ent eli cd pc)
(cond
((null (setq ent (entsel))))
((/= "CIRCLE" (cdr (assoc 0 (setq eli (entget (setq ent (car
ent))))))))
(T
(setq cd (* 2.0 (cdr (assoc 40 eli)))
pc (cdr (assoc 10 eli)))
(command "_donut" cd cd pc ^C)
(entdel ent)
(prin1)
On 11.09.2003 22:33 Mike Krous wrote:
[... a lot ...]
>Mike Krous
ok, you got one here
ruul
Message 4 of 8
Thanks for the reply jason, I tried your routine and it works like one
should...thank you very much...
Mike Krous
"Jason Piercey" wrote in message
news:3BCD499F238A930D6B7EB8B10E6D7501@in.WebX.maYIadrTaRb...
> -Jason
used
from
;Written By: Jason Piercey 07.31.01
;Revised: 01.16.02 To handle multiple selection
(defun C:Circle2Pline (/ CirEnt CirElst CirCen CirRad CirLay
CirLin CirClr CirLts PlineEnt ss
i );ss1)
(setq ss (ssget '((0 . "CIRCLE"))))
(if ss
(progn
(setq i 0 );ss1 (ssadd))
(repeat (sslength ss)
(setq CirEnt (ssname ss i)
CirElst (entget CirEnt)
CirCen (cdr (assoc 10 CirElst))
CirRad (cdr (assoc 40 CirElst))
CirLay (cdr (assoc 8 CirElst))
CirLin (cdr (assoc 6 CirElst))
CirClr (cdr (assoc 62 CirElst))
CirLts (cdr (assoc 48 CirElst))
(setq PlineEnt (list '(0 . "LWPOLYLINE")
'(100 . "AcDbEntity")
(cons 8 CirLay)
'(100 . "AcDbPolyline")
'(90 . 2)
'(70 . 1)
'(43 . 0.0)
'(38 . 0.0)
'(39 . 0.0)
(cons 10 (polar CirCen (* pi) CirRad))
'(40 . 0.0)
'(41 . 0.0)
'(42 . 1.0)
(cons 10 (polar CirCen (* pi 2.0) CirRad))
'(40 . 0.0)
'(41 . 0.0)
'(42 . 1.0)
'(210 0.0 0.0 1.0)
(if CirLin (setq PlineEnt (append PlineEnt (list (cons 6
CirLin)))))
(if CirClr (setq PlineEnt (append PlineEnt (list (cons 62
CirClr)))))
(if CirLts (setq PlineEnt (append PlineEnt (list (cons 48
CirLts)))))
(entmake PlineEnt)
(entdel CirEnt)
(setq i (1+ i))
;(ssget "p")
(princ (strcat "\n"(itoa i) " Circles converted to LwPolylines"))
(princ)
Message 5 of 8
Thanks for the reply ruul, Jasons's post was a little faster for me to
decipher, thanks again..
Mike Krous
"ruul morawetz" wrote in message
news:97FF9AAD68941430540956DED72B560A@in.WebX.maYIadrTaRb...
> Hi Mike,
> (cond
> ent))))))))
> (T
> (entdel ent)
> (prin1)
> [... a lot ...]
> >Mike Krous
> ruul
Message 6 of 8
You're welcome.
-Jason
news:66B13D32977354DF0F6B5F8A98135678@in.WebX.maYIadrTaRb...
Message 7 of 8
Don't worry, if you don't want the DONUTs I eat 'em myself 😉
Of course when trying to avoid the command function Jason's method for
sure is one to go.
OTOH I try to let AutoCAD do as much as possible 😉
and a DONUT creates a POLYLINE in the shape of a circle.
The type of the polyline is dependant on the PLINETYPE setting.
>Mike Krous
ruul
Message 8 of 8
wonderful routine it works great!!!
thanks
”Boost
