Since you have, and use the object of the line, then just change this line
(command "_layer" ent "CENTERLINES")
to
(vla-put-Layer obj "CENTERLINES")
The layer command is used to create layers, not to change the layers of
entities.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5683652@discussion.autodesk.com...
I've written a little routine to do a 66 Road Right of Way offset, what I
wanted to happen was have the orginal line selected to change to our
company's default Centerlines layer (all of our drawings have this layer),
but when I run the routine it doesn't change the layer, am I doing something
wrong?
Here is the code:
;;OFFSET ROW LINES AT 33 FEET ON BOTH SIDES OF CENTERLINE
;;Created August 3, 2007 (C) Nathan Karnes
(defun c:rowoffset (/ ent dist obj kwrd)
(vl-load-com)
(while (not ent)
(if (eq (setq ent (car (entsel "\n Please select line to multi-offset:
nil
(princ "\nTHe object you have chosen is not a line! Please select a
line to multi-offset: ")
(initget (+ 1 2 4 64))
(setq dist 33)
(initget (+ 2 4) "Yes No")
(setq kwrd (getkword "\nDo you wish to put selected line on Centerlines
layer? [Yes/No] : "))
(if (/= kwrd "No")
(setq kwrd "Yes")
(setq obj (vlax-ename->vla-object ent))
(vla-offset obj dist)
(vla-offset obj (* dist -1))
(if (eq kwrd "Yes")
(princ)
