This is an algorithm approximation that should work if coded properly. Choose your
language and code it.
let
area := get user input (string) eg. "804"
serial := get user input (string)
code := get user input (string)
rev := get user input (string)
changes := association list of changes in form: (...(tag . new value) ...) e.g. (...(cons
"AREA" area) ..) if using lisp
one possible choice of selecting drawings to process:
folders := get user inputs (strings)
dwgs := all drawings in folders
let doc be an opendbx document
foreach dwg in dwgs
open dwg as doc
foreach item in each layout.block in doc
if item.objectname = "AcDbBlockReference" and item.name="ADN01" then
foreach att in item.attributes
if change := (assoc att.tagstring changes)
att.textstring := (cdr change)
endif
end foreach
endif
end foreach
close doc and cleanup stuff
wrote in message news:5804993@discussion.autodesk.com...
This is the drawing in which i have mentioned. What i require. Like this there are
multiple sheets where i need to change only the mentioned information. Please guide me if
somebody knows the solution.
thanks
pillai
