Changing attribute from unfixed to fixed
6 REPLIES 6
gcsjlewis
664 Views, 6 Replies
I am looking for a simple way to make sure my TAG1 attribute is "FIXED".  I am looking at the properties & methods of the attribute, but i do not know what to change and what to change it to, to force it to "fixed"
6 REPLIES 6
hmsilva
in reply to: gcsjlewis
As a "demo"
(if (setq ss (ssget "_+.:E:S:L" '((0 . "INSERT") (66 . 1))))
  (progn
    (setq ent (ssname ss 0))
    (while
      (and
	(setq ent (entnext ent))
	(setq entdata (entget ent))
	(= (cdr (assoc 0 entdata)) "ATTRIB")
       (if (= (cdr (assoc 2 entdata)) "TAG1")
	 (entmod (subst (cons 70 2) (assoc 70 entdata) entdata))
HTH
Henrique
gcsjlewis
in reply to: hmsilva
Sorry that's not working. It changes the dxf code but not marking the attribute as fixed.
I see that changing dxf code 70 to 2 sets the attribute flag to constant.
I may have not specified enough, I am working with Autocad Electrical 2011. And what fixing this attribute does, is it prevents a "retag" of the TAG1 attribute.
I do not know if that's what constant is supposed to do.
________________________________
The information contained in this message is intended only for the personal and confidential use of the recipient(s) named above. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately, and delete the original message.
hmsilva
When we change the attribute to constant, the ability to enter a new tag value, will be disabled and the attribute existing value becomes fixed...
Henrique
gcsjlewis
Looking some info up I changed your code a little and it works
(defun c:fix_tag ()
(progn
(while (and (setq ent (entnext ent)) (setq entdata (entget ent)) (= (cdr (assoc 0 entdata)) "ATTRIB") )
(progn
(entmod (subst (cons 8 "WIREFIXED") (assoc 8 entdata) entdata))
(entmod (subst (cons 2 "TAG1F") (assoc 2 entdata) entdata))
); end progn
); end if
); end while
);end progn
);end if
); end defun
For future reference, All I needed to do was change "TAG1"to "TAG1F". . . Must be something internal that it looks for when I run the retag command.
I also changed the layer per our company standards.
But thanks for your help.
gcsjlewis
(defun c:fix_tag ()
(progn
(progn
); end progn
); end if
); end while
);end progn
);end if
); end defun
hmsilva
You're welcome, manamalewis
Glad you got a solution.
Henrique
”Boost
