What is the best way to change the color of two pieces of specific text in lisp? I want to change where it says (strcase ln6) & (strcase ln7) to the color of green. I tried it a couple of different ways but I'm having some trouble. First I am setting the current layer with a color of blue. I am then running the text command a couple of times. I want to run the mtext command a couple of times but I want the text to be green & I want the width factor to be .85
Solved by Kent1Cooper. Go to Solution.
Try with the command CHPROP in between the text command
(COMMAND "CHPROP" "L" "" "C" 3 "")
Your program will look like this.
((= (strcase (GETVAR "PROJECTNAME")) "IAT3")(COMMAND "-LAYER" "M" "A-ANNO-TTLB" "C" "5" "" "") (COMMAND "TEXT" "S" "ISOCP" "J" "MC" "34.0834,1.7917" ".1875" "" DATE "") (COMMAND "CHPROP" "L" "" "C" 3 "") (COMMAND "TEXT" "S" "ISOCP" "J" "MC" "33.5938,1.0833" ".1875" "" ln3 "") (COMMAND "CHPROP" "L" "" "C" 3 "") (COMMAND "-MTEXT" "33.1667,6.1350" "S" "Style-font096" "H" ".1042" "J" "TL" "W" "" (STRCASE ln6) (STRCASE ln7) "") (COMMAND "CHPROP" "L" "" "C" 3 "") (COMMAND "-MTEXT" "34.6054,6.2917" "S" "Style-font096" "H" ".1042" "J" "TL" "W" "" ln10 "") (COMMAND "CHPROP" "L" "" "C" 3 "") )
@sovby wrote:to run the mtext command a couple of times but I want the text to be green & I want the width factor to be .85
Also try with the below line for TEXT
add the below codes after the TEXT command
(setq Txt (entget (entlast)));Get last object (if (assoc 62 Txt);if not bylayer (setq Txt (subst (cons 62 3)(assoc 62 Txt)Txt));for text (not bylayer)color --> Green (setq Txt (append (list (cons 62 3))Txt));for text(bylayer) color --> Green );if (setq Txt (subst (cons 41 0.85)(assoc 41 Txt)Txt));for text width --> 0.85 (entmod Txt);Modify the text
@sovby wrote:
What is the best way to change the color of two pieces of specific text in lisp? ....
Another approach would be to save the value of the CECOLOR System Variable, set it to 3, draw whatever you want to be green, and set CECOLOR back to what it was before.
@Ajilal.Vijayan wrote:Try with the command CHPROP in between the text command
Thanks, This worked. I am not sure what the "ISOP" is for but i used the chprop command like you said. The other solution looks a little more complicated so i went with this one. Thanks to you both but with my limited knowledge of lisp at this point the simpler the better
@sovby wrote:
.... I want to run the mtext command a couple of times but ... I want the width factor to be .85
Unless it's changed in newer versions than what I have here, you can apply a width factor to Text entities, but not to Mtext entities as an override of their Style's width factor. For Text, here's another way to do so after drawing it:
(vla-put-ScaleFactor (vlax-ename->vla-object (entlast)) 0.85)
But for either Text or Mtext, you could define a Text Style with a width factor of 0.85 built in, and set that current before drawing the Text/Mtext, or don't set that current but change the Style after the fact using (subst)/(entmod) or (vla-put...) methods.
@stanovb wrote:Thanks, This worked. I am not sure what the "ISOP" is for but i used the chprop command like you said. The other solution looks a little more complicated so i went with this one. Thanks to you both but with my limited knowledge of lisp at this point the simpler the better
Sorry that's my fault.
While testing the code in my system I change the text style name Style-architxt to ISOCP(the one in my computer).
Please rename ISOCP in my code to your text style name Style-architxt.
@Kent1Cooper wrote:
@sovby wrote:.... I want to run the mtext command a couple of times but ... I want the width factor to be .85
yes, the second option is what i did but all this is good stuff to know. i am trying to teach myself this stuff as i go along & i really do appreciate everyone's help. The guy that does our routines is nearing retirement & i may end up being the person who replaces him with this stuff
stanovb wrote:.... The other solution looks a little more complicated so i went with this one. ....
The other solution would look something like this:
(setq cec (getvar 'cecolor))
(setvar 'cecolor 3)
(COMMAND "TEXT" ....)
(COMMAND "-MTEXT" ....)
(setvar 'cecolor cec)
The advantage in terms of code quantity, and probably in terms of speed, though that difference may not be noticeable, is that you don't need to run four separate CHPROP commands.
And by the way, you can perform more than one command in one (command) function:
(command
"TEXT" ....
"TEXT" ....
"MTEXT" ....
"MTEXT" ....
); end command
That would also be faster than getting out of and back into (command) functions repeatedly, though again, for something like this, the difference may not be noticeable. You could do the same if you chose to stick with CHPROP for handling the color:
(command
"TEXT" ....
"CHPROP" ....
"TEXT" ....
"CHPROP" ....
"MTEXT" ....
"CHPROP" ....
"MTEXT" ....
"CHPROP" ....
); end command
@sovby wrote:
Thanks for the help
You're welcome. Another thing you should probably add is an error handler [many examples all over this Forum] that will reset the CECOLOR System Variable in the event of some error that would prevent the regular re-setting of it from happening.
Hi sir,
(defun c:sam()
(setq p1'(10 20))
(setq cec(getvar 'cecolor))
(setvar 'cecolor 3)
(command
"text"p1"50""0""$"
when I use above coding
it shows
; error: AutoCAD variable setting rejected: CECOLOR 3
Please help me out.
Thanks in advance
Basic Learner.
@DannyNL wrote:
Value should be a string and not a number....
Just to clarify the reason for that.... Though most colors that most people use most often are designated by numbers, it can also accept color names ["Red" etc.] for the first 7 number values, as well as RGB [and some other types of] designations such as "RGB:130,200,240", and finally, also "BYLAYER" and "BYBLOCK". So the "type" of the variable has to be a string to accept all those possibilities, even when the string is just representing a number.
