• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Valued Contributor
    Change stationing text incrementally
    202 Views, 8 Replies
    04-28-2011 02:31 PM
    Is ther a way to change sttioning text incrementally? For example, I have text (0+00) spaced every 100 ft. along the bottom of a profile grid. I want to be able to pick the first, have it change to 1+00, then the second, have it changed to 2+00, etc. I have looked for a lisp routine online, but have not found one. I am not very good at creating them myself, so can anyone help?
    Please use plain text.
    Patchy
    Re: Change stationing text incrementally
    04-28-2011 02:57 PM in reply to: tommcgtx
    Why not move them 100'  ?
    Valued Contributor
    04-28-2011 03:23 PM in reply to: tommcgtx
    I am not sure I understand what you mean. I want to to pick text (0+00) already placed so that when I am finished, they read as follows:
    0+00   1+00   2+00   3+00  ..... and so on, along the bottom of my profile grid. I have some routines that will increment changes, but they only produce the same result for each text (1+00  1+00 1+00), when I want the second and third and so on picks to change by 100 more then the last.
    Valued Mentor
    04-28-2011 04:35 PM in reply to: tommcgtx
    paste then type Next_Station in command line
    (defun C:Next_Station (/ num cent)
    (vl-load-com)
    (setq num (atoi (substr (vla-get-textstring (vlax-ename->vla-object (car (entsel "\nSelect Beginning Station: ")))) 1 1)))
    (prompt "\nSelect Next Station: ")
    (while (setq cent (vlax-ename->vla-object (car (entsel))))
      (setq num (1+ num))
      (vla-put-textstring cent (strcat (itoa num) (substr (vla-get-textstring cent) 2)))
    );while
    (princ)
    );defun
    ---sig---------------------------------------
    '(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
    Patchy
    04-28-2011 07:06 PM in reply to: tommcgtx
    It was a joke (If you moved the text 100' that's where it is)
    Civil is my bread and butter :smileyvery-happy:
    04-28-2011 09:36 PM in reply to: Patchy
    (defun C:Next (/ Start TxtObject strt Next)
      	(vl-load-com)
    (cond ((and
    (setq Start (car (entsel "\nSelect Beginning Station: ")))
    (eq (vla-get-ObjectName (setq TxtObject (vlax-ename->vla-object Start))) "AcDbText")
    (setq num (vla-get-textstring TxtObject))
    (setq strt (itoa (+ (atoi (vl-string-subst  "" "+" num)) 100)))
    (not (prompt "\nSelect Next Station: "))
    (while (setq Next (car (entsel)))
    	(and
             (eq (vla-get-ObjectName (setq TxtObject (vlax-ename->vla-object Next))) "AcDbText")
    	 (not (vla-put-textstring TxtObject
    		  (strcat
    		    (substr strt 1 (- (strlen strt) 2))
    		    (substr strt (1+ (- (strlen strt) 2))))))
                     (setq strt (itoa (+ (atoi strt) 100)))
    )(princ)
    Patchy
    04-28-2011 09:43 PM in reply to: pbejse
    Lee Mac has many, many wonderful lisp
    http://lee-mac.com/numinc.html
    Valued Contributor
    04-29-2011 07:08 AM in reply to: tommcgtx
    Thank you, Sheneuph and Pbejse, the routines you both posted work great!
    Valued Contributor
    04-29-2011 07:15 AM in reply to: Patchy
    Wow! Thanks, Patchy! That program is really something. I would not even begin to know how to do something like that.
