Visual LISP, AutoLISP and General Customization
Change multiple dxf codes
7 REPLIES 7
Message 1 of 8
jberry50
335 Views, 7 Replies
I am trying to modify the dxf code 142 of a Acad_Table object. This would be easy if there were only one 142 code but there is as many 142 codes as there are columns. And this is why I would like to change say the third 142 code. How would I go about stepping my way through the previous codes to get to the correct one or ones.
Thanks for any help.
7 REPLIES 7
Message 2 of 8
EC-CAD
in reply to: jberry50
Something like this:
.. where 'entlst' is entity-list of the Entity.
(repeat (length entlst)
(setq elist (car entlst)); first set of values
(setq code (car elist)); dxf code
(setq value (cdr elist)); value
(if (= (type code) 'INT)
(progn
(if (= code 142)
(progn
........ count which one you want
........ take appropriate action
); progn
); if
); progn
); if
(setq entlst (cdr entlst)); shorten entlst list
); repeat
.. the trick is to:
Bob
Message 3 of 8
BillZ
Jon,
Use vla methods.
(vla-get-Columns test_table) ; number of colums
Command: (vla-getColumnWidth test_table "0")
2.0
(vla-setColumnWidth test_table "0" 4.0) ;set column width
Bill
Message 4 of 8
jberry50
Bill,
Thanks again for you help on this. Are these vla functions listed somewhere in the help files because I didnt see any thing for column width.
Message 5 of 8
BillZ
Just "dump" the object onto the screen.
Your vlide will have them too.
VB/Activex developers guide has it too.
Command: (vlax-dump-object test_table t)
; IAcadTable: IAcadTable Interface
; Property values:
; Application (RO) = #
; Columns = 3
; ColumnWidth (RO) = ...Indexed contents not shown...
; Direction = (1.0 0.0 0.0)
; Document (RO) = #
; FlowDirection = 0
; Handle (RO) = "423D"
; HasExtensionDictionary (RO) = 0
; HasSubSelection (RO) = 0
; HeaderSuppressed = 0
; Height = 1.17333
; HorzCellMargin = 0.06
; Hyperlinks (RO) = #
; InsertionPoint = (129.087 -10.6949 0.0)
; Layer = "0"
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; MinimumTableHeight (RO) = 1.17333
; MinimumTableWidth (RO) = 1.11
; ObjectID (RO) = 2126552552
; ObjectName (RO) = "AcDbTable"
; OwnerID (RO) = 2130586872
; PlotStyleName = "ByLayer"
; RowHeight (RO) = ...Indexed contents not shown...
; Rows = 3
; StyleName = "Standard"
; TableStyleOverrides (RO) = nil
; TitleSuppressed = 0
; TrueColor = #
; VertCellMargin = 0.06
; Visible = -1
; Width = 8.0
; Methods supported:
; ArrayPolar (3)
; ArrayRectangular (6)
; ClearSubSelection ()
; ClearTableStyleOverrides (1)
; Copy ()
; Delete ()
; DeleteCellContent (2)
; DeleteColumns (2)
; DeleteRows (2)
; GenerateLayout ()
; GetAlignment (1)
; GetAttachmentPoint (2)
; GetAutoScale (2)
; GetBackgroundColor (1)
; GetBackgroundColorNone (1)
; GetBlockAttributeValue (3)
; GetBlockRotation (2)
; GetBlockScale (2)
; GetBlockTableRecordId (2)
; GetBoundingBox (2)
; GetCellAlignment (2)
; GetCellBackgroundColor (2)
; GetCellBackgroundColorNone (2)
; GetCellContentColor (2)
; GetCellExtents (3)
; GetCellGridColor (3)
; GetCellGridLineWeight (3)
; GetCellGridVisibility (3)
; GetCellStyleOverrides (2)
; GetCellTextHeight (2)
; GetCellTextStyle (2)
; GetCellType (2)
; GetColumnWidth (1)
; GetContentColor (1)
; GetExtensionDictionary ()
; GetFieldId (2)
; GetGridColor (2)
; GetGridLineWeight (2)
; GetGridVisibility (2)
; GetMinimumColumnWidth (1)
; GetMinimumRowHeight (1)
; GetRowHeight (1)
; GetRowType (1)
; GetSubSelection (4)
; GetText (2)
; GetTextHeight (1)
; GetTextRotation (2)
; GetTextStyle (1)
; GetXData (3)
; Highlight (1)
; HitTest (4)
; InsertColumns (3)
; InsertRows (3)
; IntersectWith (2)
; IsMergedCell (6)
; MergeCells (4)
; Mirror (2)
; Mirror3D (3)
; Move (2)
; RecomputeTableBlock (1)
; ReselectSubRegion ()
; Rotate (2)
; Rotate3D (3)
; ScaleEntity (2)
; Select (8)
; SelectSubRegion (10)
; SetAlignment (2)
; SetAutoScale (3)
; SetBackgroundColor (2)
; SetBackgroundColorNone (2)
; SetBlockAttributeValue (4)
; SetBlockRotation (3)
; SetBlockScale (3)
; SetBlockTableRecordId (4)
; SetCellAlignment (3)
; SetCellBackgroundColor (3)
; SetCellBackgroundColorNone (3)
; SetCellContentColor (3)
; SetCellGridColor (4)
; SetCellGridLineWeight (4)
; SetCellGridVisibility (4)
; SetCellTextHeight (3)
; SetCellTextStyle (3)
; SetCellType (3)
; SetColumnWidth (2)
; SetContentColor (2)
; SetFieldId (3)
; SetGridColor (3)
; SetGridLineWeight (3)
; SetGridVisibility (3)
; SetRowHeight (2)
; SetSubSelection (4)
; SetText (3)
; SetTextHeight (2)
; SetTextRotation (3)
; SetTextStyle (2)
; SetXData (2)
; TransformBy (1)
; UnmergeCells (4)
; Update ()
T Message was edited by: BillZ
Message 6 of 8
They are in the help. Look for ActiveX controls.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5140722@discussion.autodesk.com...
Bill,
Message 7 of 8
jberry50
Thanks again for all your help.
Message 8 of 8
BillZ
Glad to help.
Bill
”Boost
