Visual LISP, AutoLISP and General Customization
Change blocks color
3 REPLIES 3
sudarsann
716 Views, 3 Replies
Change blocks color
I have thousands of blocks having different layers with different colors as shown in sample "blocks color.dwg".
Can any one send the lisp for changing the blocks (nested blocks) entities colors to black with out exploding and changing layer.
3 REPLIES 3
_Tharwat
in reply to: sudarsann
Why did not you reply to your preivous thread before you start a new one ?
Are we wasting our time here or what ?
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Delete-text-or-mtext-in-a-block/td-p/...
Kent1Cooper
@sudarsann wrote:
.... lisp for changing the blocks (nested blocks) entities colors to black with out exploding and changing layer.
The routine here does something slightly different, but you can probably edit it to do what you're looking for.
Kent Cooper, AIA
3wood
You can try attached CHZ20.vlx.
Step 1, Change all entities color to BYBLOCK.
Step 2, Change all BYBLOCK color to BLACK (0 0 0) or whatever color you like with a color matching rule file (a sample file attached).
Step 3, Change all block color back to BYLAYER or whatever color they were.
”Boost
