Visual LISP, AutoLISP and General Customization
Change all hatch to a particular layer
7 REPLIES 7
Message 1 of 8
esoh
2448 Views, 7 Replies
Can someone help me with a lisp that can select all hatch in a drawing with a layer called AELE, even if it is embedded in a block and change it to layer AHAT with Green colour?
The layer AHAT may or may not already exist in the drawing.
We need to run the lisp on a lot of drawings (exported from Revit) so I need to use the script to run this lisp on multiple drawings.
Thank you for your help.
Regards
Esther Soh
7 REPLIES 7
Message 2 of 8
Lee_Mac
in reply to: esoh
Try the following:
(defun c:fixhat ( / doc lay )
    (setq lay "AHAT"
          doc (vla-get-activedocument (vlax-get-acad-object))
    (vla-add (vla-get-layers doc) lay)
    (vlax-for blk (vla-get-blocks doc)
        (if (= :vlax-false (vla-get-isxref blk))
            (vlax-for obj blk
                (if
                    (and
                        (= "AcDbHatch" (vla-get-objectname obj))
                        (= "AELE" (strcase (vla-get-layer obj)))
                        (vlax-write-enabled-p obj)
                    (progn
                        (vla-put-layer obj lay)
                        (vla-put-color obj acgreen)
    (vla-regen doc acallviewports)
    (princ)
(vl-load-com) (princ)
Message 3 of 8
esoh
in reply to: Lee_Mac
Thank you very much. It works like a dream.
Message 4 of 8
Lee_Mac
in reply to: esoh
Message 5 of 8
shawn.p.phillips
Hey guys, I used your lisp routine and made a few modifications to do what I needed it to do which is convert any hatch named "FP_*" (the hatch has a different number after it depending on the drawing its in) to a layer that I created in another routine.  It works great but for some reason it won't convert one of the hatches.  I think the reason is that its not a block and I'm not sure this routine is picking it up.  Even if I single it out, add a line that specifically looks for the hatch name "FP_76" it won't grab it.  Can you help me out here?
(defun c:earth_hat254 ( / doc)
    (vlax-for blk (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
            (vlax-for obj blk
                (if (and (= "AcDbHatch" (vla-get-objectname obj))
                         (= "FP_*" (strcase (vla-get-patternname obj)))
                    (progn
                        (vla-put-layer obj "EARTH-HATCH_254")
                        (vla-put-color obj 256)
    (princ)
Message 6 of 8
mtaras
Dear Lee,
could your lisp be applied to selected block (multiple selected blocks) instead of all blocks in drawing?
I tried to ad another filter and failed (error: malformed list on input 🙂
(defun c:fixhat1 ( / doc lay ss1 )
    (setq lay "AHAT"
          ss1 (ssget "_X" '((0 . "INSERT")))
    (vlax-for blk (vla-get-blocks ss1)
            (vlax-for obj blk
                (if
                    (and
                    (progn
    (princ)
Kindest regards,
Message 7 of 8
Kent1Cooper
in reply to: mtaras
@mtaras wrote:
.... selected block (multiple selected blocks) instead of all blocks in drawing? .... (error: malformed list on input ....
    (setq lay "AHAT"
          doc (vla-get-activedocument (vlax-get-acad-object)) ; <-- add right parenthesis
ss1 (ssget "_X" '((0 . "INSERT"))); <-- remove "_X" if you want User selection ) ....
[Sorry -- I've edited this quite a few times....]
Do the above at the least, for the User selection and the malformed-list error -- other changes may also be needed, for example, is this a valid construction?
Kent Cooper, AIA
Message 8 of 8
mtaras
in reply to: Kent1Cooper
Hi Kent!  thank you very much for comment. After your instructions, the code runs with out errors 🙂 Thanks to Lee Mac for his coding being so transparent, good for study even for an evergreen like me!
Further an issue here is present, as you mentioned about construction, new lisp changes all hatches within all blocks in doc, and not only within a selected block, which will take me some study again, to put effect only on selected block.
”Boost
