Dear All,
Please find the attached. I have too many blocks with specific layers inside.
Could you help me to develope lisp can change all to layer 0 but keep color and linetype as it is.
I will use this as a part of script to change multiple block.
Solved by Lee_Mac. Go to Solution.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
This is great code! Is there a way to make it so you can select an entire drawing and apply the routine to ALL blocks?
@daviddangelantonio wrote:
.... Is there a way to make it so you can select an entire drawing and apply the routine to ALL blocks?
The link in Post 11 should do that for you.
Lee_Mac
I try to use your script but I am getting:
error: no function definition: LM:APPLYTOBLOCKOBJECTS
What I am doing wrong?
Your help is much appreciated
