• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual LISP, AutoLISP and General Customization
    Valued Contributor
    Accepted Solution
    Change Dynamic Block Property "Scale Uniformly" Automatically
    529 Views, 4 Replies
    12-16-2010 09:01 PM
    G'day,
    Been trying to figure out how to change the Scale Uniformly property in dynamic blocks accross hundreds of drawings using either/or scripts, lisp, vba or anything else that might do the job.
    WIth my limited knowledge of programming im wondering if there is someone out there that may be able to help me out?
    just need to open the drawing and select the block (one block per drawing) then edit the scale uniformly property within the block, save then close the drawing and move onto the next drawing.
    Thank you in advance for your help with this matter.
    Jason
    Please use plain text.
    Valued Mentor
    Re: Change Dynamic Block Property "Scale Uniformly" Automatically
    12-17-2010 12:11 AM in reply to: jason.estas
    see if this helps... no error control
    (setq obj (vlax-ename->vla-object (car (entsel)))
          blknm (vlax-get obj 'Effectivename)
    (vlax-for blk (vla-get-blocks
                    (vla-get-ActiveDocument
                      (vlax-get-acad-object)))
      (if (eq blknm (vla-get-Name blk))
        (vlax-put blk 'BlockScaling acUniform))
    ~~~Civil 3D 2008~~~
    Valued Contributor
    msarqui
    02-06-2013 04:24 PM in reply to: lpseifert
    Sorry for the question but: How I use it?
    I tred this but I get an error when autocad starts...
    (Defund c:BUS ()
    *Expert Elite*
    02-06-2013 06:43 PM in reply to: msarqui
    (Defund c:BUS ()
    (Defun c:BUS ()
    Valued Contributor
    msarqui
    02-07-2013 10:14 AM in reply to: pbejse
    hahaha. I guess I was tired...
    Now it works fine but only one block at a time. I mean, it does not change automaticaly nested blocks. Also it does not accept "select all". I think I'll try to find another one :smileysad:
    Thanks pbejse!
