Visual LISP, AutoLISP and General Customization
Can't get this lisp to work!
4 REPLIES 4
TomTom111
508 Views, 4 Replies
I have an attribute editor LISP that changes the value of an attribute within a block.
Recently, the LISP needed a face lift due to changes in standards, sp this is what i am working on...
(defun c:`` ( / _AttFunc b tbl dname attval a b)
(vl-load-com)
(defun _AttFunc	(en lst / vals v)
  (mapcar (function
	    (lambda (at)
	      (setq vals (list (vla-get-tagstring at) (vla-get-textstring at)))
	      (if (and lst (setq v (assoc (car vals) lst)))
		(vla-put-textstring at (cadr v))
	      vals
	  (vlax-invoke
	    (if	(eq (type en) 'VLA-OBJECT)
	      en
	      (vlax-ename->vla-object en)
	    'Getattributes
(setq Y (getstring "Enter building number: "))
(setq Z (getstring "Enter project number: "))
(setq Y (strcat Y "-"))
(setq Z (strcat Y Z))
(if (and
	(= (getvar 'Dwgtitled) 1)
	(setq b nil tbl (ssget "_X" '((0 . "INSERT")(66 . 1)(2 . "TB_PARAMOUNT_ELC"))))
	(setq p (vl-string-position 95
		(setq dname (vl-filename-base (getvar 'dwgname))) nil T))
        (setq dname (substr dname (+ 2 p)))
        (setq attval (_AttFunc (setq tbl (ssname tbl 0)) nil))
        (vl-every '(lambda (x) (if (setq a (assoc x attval))
                                   (setq b (cons a b)))) '("DWG"))
    (_AttFunc tbl (list (list "DWG" (strcat  (cadr (assoc Z attval)) "-" dname))))
  	(princ "\Incomplete data to process")
  (princ)
So now whenever I run this code, i get an "; error: bad argument type: stringp nil" error.
I am wanting to update the attribute value with the Building number "-" Project number "-" the last 3 digits of the DWG file name.
So something to the effect of "13-21-100", whatever the user inputs are.
I'm missing something simple here, i know it, but i can't seem to figure it out.
So i am turning to the awesome community that is here in the VLISP forums!
Thanks as always!
4 REPLIES 4
hmsilva
in reply to: TomTom111
Change
to
(_AttFunc tbl (list (list "DWG" (strcat Z "-" dname))))
Henrique
pbejse
Thanks as always!
---> Source? <----
I think i can FIX that code for you TomTom111
1. You dont need vl-every if theres only one condition . ["DWG"]
2. It will crash if value for variable Z is not found in variable attval  hence the error
At any rate, i'm not sure of your intention for the final string result as you area targeting a specifc TAG from attval.
TomTom111
in reply to: hmsilva
@hmsilva wrote:
Change
to
Henrique
Smiley Embarassed
Works like a charm.
Not sure what I was trying to do yesterday. LISP fatigue perhaps.
Thanks very much for the reply!
hmsilva
You're welcome, TomTom111
Glad I could help
Henrique
”Boost
