Visual LISP, AutoLISP and General Customization
Can't get my program to run
4 REPLIES 4
clippincott-CL
506 Views, 4 Replies
I have very little experience with AutoLISP, or programming in general, so sorry about this completely basic question.
I wrote a little program, the one I have attached here, that I'm hoping will execute the "exporttoautocad" command each time I open a drawing.  I have created a file named "acaddoc.lsp", added the code (load "aec2.lsp") to it and put this file in my "Support File Search Path", as I read to do in these forums.  From what I understand this should make it so my "aec2.lsp" program runs each time I open a drawing.  Problem is, it isn't happening and I don't know why.
Is there something in how I've constructed the "aec2.lsp" program that is making it not run?  Please take a look at the admittedly meager little file and let me know if there is something I have missed in how I wrote it or if I need to do something else to make it so this file loads and runs each time I open a drawing.
Thanks for any help offered.
4 REPLIES 4
hmsilva
in reply to: clippincott-CL
"... I have created a file named "acaddoc.lsp", added the code (load "aec2.lsp")..."
need to call the function in the acadoc.lsp
(AWAY)
HTH
Henrique
clippincott-CL
in reply to: hmsilva
Such a quick reply!  Such an easy solution!  Thank you! 🙂
hmsilva
You're welcome.
Glad I could help
Henrique
scot-65
Another method is to treat the program like a script by removing the opening and closing parenthesis:
;;;;;(defun XXX
[program here]
;;;;;);end defun
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
