Hey,
I am using the following line in a script file in my AutoCAD 2013:
MOVE all .356,.425 .435,.435
It has a return at the end to the next line of the script.
when I run it, AutoCAD reports this:
Command: MOVE
Select objects: all 212 found
2 were not in current space.
Select objects:
Specify base point or [Displacement] <Displacement>: .356,.425
Specify second point or <use first point as displacement>: .435,.435
But when I query the object that is supposed to be at 0.435,0.435 it remains at 0.356,0.425. In other words, nothing is moving. I have a SAVE at the end of the script. It doesn't matter whether I run it in a batch, or call it up in the drawing session, it just doesn't want to MOVE anything.
any ideas where I went wrong?
Thanks.
Rats. It won't work. Some files work, but not the majority. Nothing is frozen. When I run the script in batch I can see the objects all highlight for a split second, but they don't move. I can't see any reason why they shouldn't. I guess I should be glad of job security - I have a couple hundred of these to get through. At least the other lines of the script are working.
Command: _.move
Select objects: all
188 found
Select objects:
But nothing moves!
Hey, I think OSMODE to 0 works. Why, I do not know. I should set it back to 63 at the end of the script, which is where I usually have it, right?
An alternative approach [which actually uses less code than setting OSMODE to 0 and then back again afterwards], when you're only dealing with a couple of points, is to disable Osnap momentarily for each:
MOVE all none .356,.425 none .435,.435
That has the further advantage that if you have an Osnap combination different from your usual for some legitimate reason, it will leave that as you have it.
