Can you modify the names of the sheets with lisp? We have a project startup routine that copies files from a central network location into our project directory & renames the files to for instance project x plan.dwg. When i copy over my sheet set template it refers to the name that is in the the central netowrk location which is called 0000 storename plan.dwg. I want the new sheet set to be linked with a drawing called projectx plan.dwg. Im trying to avoid having to edit the sheet manager for every project that we do.
