Visual LISP, AutoLISP and General Customization
Calculating Depth Ranges for Sanitary Sewer
9 REPLIES 9
Message 1 of 10
JCanaan
951 Views, 9 Replies
I have an old lisp that used to calculate the stations and depth of sanitary sewer. It will not run in Civil 3D (even if I explode the entities). It is not getting a variable passed to it.
Sewer is paid at a price for 0 to 6 feet depth, 6 to 8 feet, 8 to 10 feet, and so forth (2 ft increments). It is using a line for the ground and line that represents the bottom of the sanitary sewer. Does anyone know how to get this information our of Civil 3D with or without an lisp. I don't have the knowlege to re-write the lisp.
JMC
9 REPLIES 9
Message 2 of 10
stevor
in reply to: JCanaan
Start by posting that lsp routine, as an attachment if longer than a few lines.
S
Message 3 of 10
JCanaan
in reply to: stevor
this is the original list and program that created a printed report with information. Any suggestions/help would be appreciated. I tried to find company that originally wrote it without success.
Message 4 of 10
JCanaan
actual lisp
Message 5 of 10
CADaSchtroumpf
Your code use old polyline extract
Perhaps try to change the fonction:
  (DEFUN GETVERTS (edata / lst)
    (while (= (**** 0 (setq edata (entget (entnext (**** -1 edata))))) "VERTEX")
      (setq lst (cons (list (car (**** 10 edata)) (cadr (**** 10 edata))) lst))
    ) lst
 with
    (setq lst (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) edata)))
 and for me
(command "._PEDIT" gline "_Y" "_J" gsset "" "_X") (setq gline (entlast)) not work's
but
(command "._PEDIT" gline "_J" gsset "" "_X") (setq gline (entlast)) is OK
Message 6 of 10
JCanaan
in reply to: CADaSchtroumpf
I made edits you suggested and this is message I get
STAKEOFF - Copy.LSP successfully loaded.
Command:
Command:
Command: STO
Sewer Line Take-Off v1.1 -- Copyright (c) 1996 Command Software & Consulting
Select each line segment at bottom of sewer:
Select objects: Specify opposite corner: 3 found
Select objects: Specify opposite corner: 3 found (1 duplicate), 5 total
Select objects: Specify opposite corner: 3 found (1 duplicate), 7 total
Select objects: Specify opposite corner: 2 found (1 duplicate), 8 total
Select objects:
Select line segment at grade:
Yes or No, please.
I am able to select line segment at grade and it begins to run but stops and above is what is printed. It creates file but it is empty.
I attached edited file.
Message 7 of 10
CADaSchtroumpf
I don't understand very well the philosophie of this code, but i hope that is good!
Message 8 of 10
JCanaan
Still blows up. I guess I will keep working on it when I have time. Thanks.
Message 9 of 10
~Opie
Do you have a sample drawing of the Civil 3D entities? Or even one that shows similar to your initial description?
Message 10 of 10
JCanaan
in reply to: ~Opie
Below is error message I get when running lisp. The remainder of profile in drawing I have attached was created in Civil 3D 2012. I exploded it so I can just have lines which is what the lisp needs. Ultimately I would not want to do this, but for now I could do it and create a drawing to just do the calculations in at the end. Any suggestions/help would be appreciated.
Command: STO
Select objects: 1 found
Select objects: Specify opposite corner: 2 found (1 duplicate), 2 total
Select objects: Specify opposite corner: 1 found, 3 total
Select objects:
Object does not intersect an edge.
ERROR:  Sewer and grade line must start and end with the same X coordinate.
”Boost
