• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual LISP, AutoLISP and General Customization
    Valued Contributor
    COUNT DYNAMIC BLOCK INCLUDING TOTAL LENGTH
    321 Views, 21 Replies
    04-02-2012 01:18 PM
    Hi all,
    Can some one help me a lisp to count dynamic block including total lenght.
    Please use plain text.
    Valued Mentor
    _Tharwat
    Re: COUNT DYNAMIC BLOCK INCLUDING TOTAL LENGTH
    04-02-2012 01:26 PM in reply to: tdcad
    Hi
    The first block into your drawing is not considered as a Dynamic Block , so the following routine would would the trick on
    the same dynamic blocks that you uploaded with you sample drawing .
    (defun c:TesT (/ total selectionset count intger selectionsetname vl a b) (vl-load-com)
      ;;; Tharwat 02 . April . 2012 ;;;
      ;; Count number of selected Dynamic blocks and length of total selected dynamic blocks
      (if (setq total 0
                selectionset
                 (ssget '((0 . "INSERT") (2 . "`*U*")))
        (progn
          (setq count (sslength selectionset))
          (repeat (setq intger (sslength selectionset))
            (setq selectionsetname
                   (ssname selectionset
                           (setq intger (1- intger))
            (setq vl (vlax-ename->vla-object selectionsetname))
            (vla-getboundingbox vl 'a 'b)
            (setq total (+ total
                           (distance (list (car (vlax-safearray->list b))
                                           (cadr (vlax-safearray->list a))
          (print (strcat " Total number of Dynamic Blocks :"
                         (itoa count)
          (print (strcat " Total lengths of Dynamic Blocks :"
                         (rtos total 2)
        (princ)
      (princ)
    Valued Mentor
    _Tharwat
    04-02-2012 01:49 PM in reply to: tdcad
    This one is a little bit better for the same block name and wth message box .
    (defun c:Test
                  (/ total selectionset count intger selectionsetname a b)
      (vl-load-com)
      ;; Count number of selected Dynamic blocks and length of selected dynamic blocks
      (if (setq total 0
                selectionset
                          (-4 . "<or")
                          (2 . "`*U*")
                          (2 . "_P1000")
                          (-4 . "or>")
        (progn
            (vla-getboundingbox
              'a
              'b
          (alert (strcat " Total number of Dynamic Blocks :"
                         (itoa count)
                         "\n"
                         (rtos total 2)
        (princ)
      (princ)
    Distinguished Contributor
    04-02-2012 05:42 PM in reply to: _Tharwat
    Hi Tharwat, I know the OP show only the _p1000 "original" block.
    But, what could be happen if there is another "original" block , and furthermore, what about if it have a inclination?.
    I think the user shall pick the block to size and count, then using the EFFECTIVE NAME , select all them , or split them from the inserted blocks.
    If they are not a 0 inclination or slope , there will be a issue to get the real distance.
    Gabriel.
    *Expert Elite*
    04-02-2012 08:08 PM in reply to: tdcad
    Try this
    (defun c:CDL ( / ss val ttl)
          (setq  bn "_P1000"
                 ttl 0 i 0)
          (if (ssget "_X" (list '(0 . "INSERT")(cons 2 (strcat bn ",`*U*"))))
      	(progn
    	      (vlax-for  itm  (setq ss (vla-get-activeselectionset
    	                               (vla-get-activedocument
    	                                     (vlax-get-acad-object))))
    	 (if (and (= :vlax-true
                         (vla-get-isdynamicblock itm))
                      (setq val  (vl-remove-if-not
                                       '(lambda (x)
                                              (eq   (vla-get-PropertyName
                                                          x)
                                                    "Distance"))
                                       (vlax-invoke
                                             itm
                                             'getdynamicblockproperties))))
                   (setq ttl (+ ttl (vlax-get (car val) 'value)) i (1+ i))
    	 (vla-delete ss)
                  (alert (strcat "Number of Blocks: " (itoa i)
                                "\nTotal Length: " (rtos ttl 2 2)))
        (prompt "\n** Nothing selected ** "))
      (princ))
     HTH
    04-02-2012 08:18 PM in reply to: pbejse
    Hi PBEJSE , thanks again for it (vlax-invoke itm 'getdynamicblockproperties))))
    *Expert Elite*
    04-02-2012 08:32 PM in reply to: devitg
    Good for you Devtg
    Cheers
    Valued Mentor
    _Tharwat
    04-03-2012 03:55 AM in reply to: devitg
    Gabriel.
    You're right devitg .
    I knew that and I did not write the rotine before taking a look at the attached drawing . if all blocks are similar to the once in the drawing , the code would give correct lengths , otherwise there be a mistake in the total of lengths .
    the routine that given by pBe is very accurate completely .
    Thanks a lot.
    *Expert Elite*
    04-03-2012 05:26 AM in reply to: _Tharwat
    _Tharwat wrote:
     You're right devitg .the routine that given by pBe is very accurate completely .
    Thanks a lot.
    Not at all Tharwat. it lacks error trapping besides i missed this part
    (= :vlax-true (vla-get-isdynamicblock itm))
        (eq (strcase (vla-get-effectivename itm)) bn)
       (setq val  (vl-remove-if-not......
    But thanks nonetheless tharwat.
    Cheers
    Valued Contributor
    04-04-2012 12:13 PM in reply to: tdcad
    Thanks for all, but what I mean is total of length for each piece including original block (_P1000) so I can able to cut them off.
