Valued Contributor
Message 1 of 23 (460 Views)
COUNT DYNAMIC BLOCK INCLUDING TOTAL LENGTH
460 Views, 22 Replies
04-02-2012 01:18 PM
Hi all,
Can some one help me a lisp to count dynamic block including total lenght.
Distinguished Mentor
_Tharwat
Message 2 of 23 (459 Views)
Re: COUNT DYNAMIC BLOCK INCLUDING TOTAL LENGTH
04-02-2012 01:26 PM in reply to: tdcad
Hi
The first block into your drawing is not considered as a Dynamic Block , so the following routine would would the trick on
the same dynamic blocks that you uploaded with you sample drawing .
(defun c:TesT (/ total selectionset count intger selectionsetname vl a b) (vl-load-com)
  ;;; Tharwat 02 . April . 2012 ;;;
  ;; Count number of selected Dynamic blocks and length of total selected dynamic blocks
  (if (setq total 0
            selectionset
             (ssget '((0 . "INSERT") (2 . "`*U*")))
    (progn
      (setq count (sslength selectionset))
      (repeat (setq intger (sslength selectionset))
        (setq selectionsetname
               (ssname selectionset
                       (setq intger (1- intger))
        (setq vl (vlax-ename->vla-object selectionsetname))
        (vla-getboundingbox vl 'a 'b)
        (setq total (+ total
                       (distance (list (car (vlax-safearray->list b))
                                       (cadr (vlax-safearray->list a))
      (print (strcat " Total number of Dynamic Blocks :"
                     (itoa count)
      (print (strcat " Total lengths of Dynamic Blocks :"
                     (rtos total 2)
    (princ)
  (princ)
____________________________________________________
Get learn and learn and practice , to become experienced guy .
_Tharwat
Message 3 of 23 (454 Views)
04-02-2012 01:49 PM in reply to: tdcad
This one is a little bit better for the same block name and wth message box .
(defun c:Test
              (/ total selectionset count intger selectionsetname a b)
  (vl-load-com)
  ;; Count number of selected Dynamic blocks and length of selected dynamic blocks
  (if (setq total 0
            selectionset
                      (-4 . "<or")
                      (2 . "`*U*")
                      (2 . "_P1000")
                      (-4 . "or>")
    (progn
        (vla-getboundingbox
          'a
          'b
      (alert (strcat " Total number of Dynamic Blocks :"
                     (itoa count)
                     "\n"
                     (rtos total 2)
    (princ)
  (princ)
Message 4 of 23 (440 Views)
04-02-2012 05:42 PM in reply to: _Tharwat
Hi Tharwat, I know the OP show only the _p1000 "original" block.
But, what could be happen if there is another "original" block , and furthermore, what about if it have a inclination?.
I think the user shall pick the block to size and count, then using the EFFECTIVE NAME , select all them , or split them from the inserted blocks.
If they are not a 0 inclination or slope , there will be a issue to get the real distance.
Gabriel.
Message 5 of 23 (437 Views)
04-02-2012 08:08 PM in reply to: tdcad
Try this
(defun c:CDL ( / ss val ttl)
      (setq  bn "_P1000"
             ttl 0 i 0)
      (if (ssget "_X" (list '(0 . "INSERT")(cons 2 (strcat bn ",`*U*"))))
  	(progn
	      (vlax-for  itm  (setq ss (vla-get-activeselectionset
	                               (vla-get-activedocument
	                                     (vlax-get-acad-object))))
	 (if (and (= :vlax-true
                     (vla-get-isdynamicblock itm))
                  (setq val  (vl-remove-if-not
                                   '(lambda (x)
                                          (eq   (vla-get-PropertyName
                                                      x)
                                                "Distance"))
                                   (vlax-invoke
                                         itm
                                         'getdynamicblockproperties))))
               (setq ttl (+ ttl (vlax-get (car val) 'value)) i (1+ i))
	 (vla-delete ss)
              (alert (strcat "Number of Blocks: " (itoa i)
                            "\nTotal Length: " (rtos ttl 2 2)))
    (prompt "\n** Nothing selected ** "))
  (princ))
 HTH
Message 6 of 23 (435 Views)
04-02-2012 08:18 PM in reply to: pbejse
Hi PBEJSE , thanks again for it (vlax-invoke itm 'getdynamicblockproperties))))
Message 7 of 23 (433 Views)
04-02-2012 08:32 PM in reply to: devitg
Good for you Devtg
Cheers
_Tharwat
Message 8 of 23 (422 Views)
04-03-2012 03:55 AM in reply to: devitg
Gabriel.
You're right devitg .
I knew that and I did not write the rotine before taking a look at the attached drawing . if all blocks are similar to the once in the drawing , the code would give correct lengths , otherwise there be a mistake in the total of lengths .
the routine that given by pBe is very accurate completely .
Thanks a lot.
Message 9 of 23 (413 Views)
04-03-2012 05:26 AM in reply to: _Tharwat
_Tharwat wrote:
 You're right devitg .the routine that given by pBe is very accurate completely .
Thanks a lot.
Not at all Tharwat. it lacks error trapping besides i missed this part
(= :vlax-true (vla-get-isdynamicblock itm))
    (eq (strcase (vla-get-effectivename itm)) bn)
   (setq val  (vl-remove-if-not......
But thanks nonetheless tharwat.
Cheers
Valued Contributor
Message 10 of 23 (393 Views)
04-04-2012 12:13 PM in reply to: tdcad
Thanks for all, but what I mean is total of length for each piece including original block (_P1000) so I can able to cut them off.
You are not logged in.
Ask the Community
