burst command is not working
(command "burst" "all")
above command is showing unknown command "BURST"
@jth-wspusa wrote:
How do I use the BURST command inside of another lisp? My list creates a selection set then I call for the BURST command and I want to supply P for previous and an enter to complete the burst command. I have 350 files to run this lisp on through a script and I don't want to have to hit the P enter enter.
(setq deablk (ssget "X" (list (cons 2 "*"))));creates block selection set
(C:BURST)
I've also tried these lines but the BURST command come back as unknown.
(load "C:/Program Files/AutoCAD Civil 3D Land Desktop Companion 2008/Express/Burst.lsp")
(defun C:BURST () (command "BURST"))
(command "BURST" "P" "");explodes block selection set
What am I missing.
This is likely because BURST is an express tools autolisp routine, as stated earlier in this thread.
You will need to have express tools installed on your autocad for the command to work.
OP- and this is for your info, I could care less but figure it'd be the decent thing to let you know...that,
"HTH" is an acronym for Hope that Helps.
The forum name of the individual who used the acronym is "Mark".
HTH 😛
