Hai,
To get the 'File Selection dialog box' in AutoCAD via LISP, which command should I use other than 'GETFILED' ?
I have a program which using GETFILED to select the drawing file , but I think this dialog box size is too small to browse folder/file , as you cant see the favorites list and you cant resize the dialog box.
AJIL
Solved by pbejse. Go to Solution.
@Anonymous wrote:Hai,
AJIL
Express Tool utility:
You need this fas file loaded .
"acetutil2.fas"<-----
(setq file (acet-ui-getfile
"Open file"
"dwg"
"Drawing files"
8))
HTH
Hai ,
Thanks for the reply.
Yeah this was the one , which I was looking for.
As you mean by acetutil2.fas should be loaded , I think if you have Express tools in your AutoCAD this fas file should load automatically....is that right ?
Thanks for your help...
AJIL
AJIL
You're welcome AJIL, Glad i could help
I seldom express tools I guess it does load automatically.
Cheers
