Just curious david,
but why didnt his version of 'fix' work as opposed to yours; is he applying
the fix on each line similar to the way mapcar is doing it?
ta
"David Bethel" wrote in message
news:4149eb41$1_1@newsprd01...
> There are lots of ways to do that 1;
> (initget 1)
> (setq p1 (getpoint "\nFirst Corner: "))
> (initget 1)
> (setq p2 (getcorner p1 "\nOpposite Corner: "))
> (setq p1 (mapcar 'fix p1)
> p2 (mapcar 'fix p2))
> This always rounds down positives, rounds up negatives. If you need to
> round to the nearest point, then more code would be required. -David
> rjt205 wrote:
> > I am trying to teach myself some Autolisp, people who new it are now
gone. what i need to do is pick 2 diagonal points and then draw a rectangle
a set distance around it. No problem there, but the rectangle must be an
integer. I've tried using FIX but with no luck. Any help would be greatly
appreciated
