Batch find and replace from an excel file
12 REPLIES 12
Message 1 of 13
ehughes
7734 Views, 12 Replies
I have a need for an Acad 2014 LISP that will read Excel and whats in column A will be replaced with whats in column B of the same row, about 3200 rows of it. Anyone ever found anything like that? I found something but it doesnt read from or copy from excel. Help please?!?
Evan
12 REPLIES 12
Message 2 of 13
3wood
in reply to: ehughes
Do you refer to block attributes?
Message 3 of 13
ehughes
in reply to: 3wood
No just text, they are part numbers from old the manufacturer in column A that need to be current manufaturer part/model number in column B.
Message 4 of 13
3wood
What is the entity type in AutoCAD? Table? Mtexts with lines? Texts? Blocks?
Can you upload a sample drawing with a sample Excel file?
Message 5 of 13
Lee_Mac
You could use my BFind program for this task.
As it stands, the current version of the program doesn't allow you to import find & replace pairs from an external file, however, you can perform the following steps to import the data into the program:
Start the program, enter a few find & replace entries, and save the list using an arbitrary reference. Then exit the program and type at the AutoCAD command-line:
(findfile "LMAC_BFind_SavedSearches_V2-0.txt")
This will give the location of the file that the program uses to store the find & replace pairs.
I would suggest that you first save a few different search references with the program (using the 'Save' button) and you will then easily see the required format of this text file. The file may then be edited manually to add search/replace items from your spreadsheet, providing that you keep to the same format so that it may be read by the program in the expected format. As a tip, I would suggest first saving your Excel spreadsheet as a tab-delimited text file.
I hope this helps,
Lee
Message 6 of 13
ehughes
in reply to: Lee_Mac
AWESOME!! That worked great! Thank you very much!
Message 7 of 13
Lee_Mac
Glad to hear it evan - you're welcome!
Message 8 of 13
joãomoura5585
You are simply the best !
thank Lee Mac
Message 9 of 13
vinay.moogi777
hi lee mac
i want change in each and every sheet this bfind can u provide me any solution
Message 10 of 13
iamwonder
 I have download "bfind",but it dosent work with chinese ,how can i do?
Message 11 of 13
teneilew
I realize this is a very old post but, Lee Mac, you have saved me hours or work once again! Thank you!
T
Message 12 of 13
yarik89V9ZK2
 AutoReplaceCAD from kdmsoft solved the problem, I do not give a link, you will find it yourself in Google
Message 13 of 13
shafiq_adha
thanks man! you just help me replace 250 tagging in 5 minutes
”Boost
