• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Distinguished Contributor
    Re: Batch convert DGN to DWG
    04-27-2012 02:17 AM in reply to: ddotten
    I suspect that the action of opening a new drawing stops the execution of the lisp routine in the original drawing unttil the focus is returned to the original drawing. This is the reason I use a different mode for DGNIMPORT in AutoCAD 2012. I think that I'm not able to find a solution for AutoCAD version 2011.
    Please use plain text.
    New Member
    05-30-2012 09:26 PM in reply to: mmoolhuysen
    first thankx sir
    i try this tool in autocad 2012 but it is not working sir,some option is comming (Enter filename for DGN import:smileyhappy:
     i need thiis lisp ,so plse reply send me my mail ,what iam do,
    thanking you sir
    mohan
    (mm4803@gmail.com)
    Member
    09-17-2012 10:21 AM in reply to: huaer605
    This one work but is not exact a better program is needed.
    10-08-2012 01:46 AM in reply to: OzzNick
    I've managed to batch convert multiple DGN files using 3rd party software.
    After, I've written my lisp
    (command "-mapimport" "DGN_V7_V8" nn3 "Y" "c:\\hatch.ipf" "I" "yes" "")
    and tested it on one DGN
    i've bought and installed this:
    http://www.cadfx.com/batchscr/
    and applyed my lisp on bunch of empty DWG files named as DGN files so when using DWGNAME variable i managed to import dgn...
    New Member
    04-03-2013 11:54 AM in reply to: mmoolhuysen
    I updated the paths for tx1, tx2 and tx3. I left tx4 as "default". When I tried running the lsp, I got the error msg:
    Command: DGNI
    ; error: bad argument type: FILE nil
    What am I doing wrong?
    Thanks!!
