• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Active Contributor
    Batch convert DGN to DWG
    7936 Views, 24 Replies
    11-23-2011 01:46 AM
    Hi All,
    My work needs to convert thousands of DGN files to DWG. We are using AutoCAD 2012. Is it possible to batch convert dgn files with a LISP and a mapping file? Anyone have a LISP for this?
    Any help is appreciated.
    Arul
    Please use plain text.
    Valued Contributor
    rick.hberg
    Re: Batch convert DGN to DWG
    11-23-2011 11:22 AM in reply to: arulanand12
    Is it safe to say you don't have any Microstation installs?  If you do, or if you can find one, use Utilities -> Batch Convert.
    Otherwise, hopefully someone else can respond....
    If I attach a dgn and then type  -xref, ?, *,  to list all xrefs, the dgn is not listed, so I don't know what it is inside the dwg.
    Civil 3D 2011
    Windows 7 x64
    alanjt_
    11-23-2011 11:36 AM in reply to: rick.hberg
    Do you have the DGNIMPORT command in 2012?
    Active Contributor
    11-23-2011 07:19 PM in reply to: alanjt_
    First of all thank you for your replies.
    Hi rick.hberg,
    We do not have Microstation.
    Hi alanjt_ ,
    Yes. We have DGNIMPORT command in AutoCAD 2012.
    Valued Contributor
    11-27-2011 07:47 AM in reply to: arulanand12
    Very easy to write a batch Autolisp routine. All you would need is to create an ASCII text file (flat file) of all of the *.dgn files you wish to import, including full path. Autolisp program would then open file, read the first line, import the *.dgn file into AutoCAD, save as a *.dwg file , close, read the next line and repeat until all *.dgn files have been imported.
    I can write the program for you, however I need for you to send me a *.dgn file to complete the program. Not familiar with *.dgn files and need a sample file to see how the DGNIMPORT function works.
    Active Contributor
    11-30-2011 04:21 AM in reply to: lgabriel
    Hi Gabriel,
    Hope your method will help for me. I have attached a .DGN file here.
    Arul
    12-07-2011 01:37 PM in reply to: arulanand12
    Any luck with this LISP?  I'm also looking to batch convert alot of DGN files to DWG.  I've just begun learning programming (LISP & C) so I'm not anywhere close to the level of knowledge I need to create such a LISP.  However we are working on a project which is dragging because of the number of dgn files we must import & view.  Very exhausting.
    Active Contributor
    12-08-2011 12:10 AM in reply to: arulanand12
    Still digging for it. I will post here, once I get LISP code.
    New Member
    03-21-2012 08:45 PM in reply to: arulanand12
    Free download Professional batch DGN to DWG Converter in various version
    Distinguished Contributor
    03-30-2012 07:22 AM in reply to: arulanand12
    I've written the attached Lisp routine for converting multiple DGN files into DWG files. It expects a text file with the drawing names to convert as input. I've used it to convert large quantities of drawings.
    The user has to make the necessary adjustments to the following variables:
    tx1 = path and name of a file that holds a list with names for all the *.dgn's to be imported, names of *.dgn drawings may be written without extension, as well as with extension, in plain text format, no return after the last line.
    tx2 = the path for the input folder, containing the actual *.dgn files to import.
    tx3 = the path for the output folder, where the drawings converted into *.dwg will be saved, (routine assumes that the *.dwg files do not exist yet)
    tx4 = name of the drawing model to import
    Start the command by typing DGNI
    The routine reads drawing names from the file given in tx1 line-for-line.
    In each loop it performs a DGNIMPORT from the folder given as tx2 into the existing AutoCAD drawing,
    does a Zoom Extends, saves the converted drawing result as *.dwg in the folder given as tx3,
    and finally restores the drawing to its original state, ready to receive the next DGNIMPORT loop.
    The DGNIMPORT command trips when the name of the *.dgn to be imported contains a comma, I advise to rename the drawings having this issue.
    With friendly greetings, M. Moolhuysen.
