Visual LISP, AutoLISP and General Customization
MAD_MONK42
Message 1 of 18 (886 Views)
Batch Rename Blocks
886 Views, 17 Replies
02-29-2008 07:45 AM
Please excuse if this question has already been posted.
(I couldn't find one exactly)
I would like to batch rename all blocks in a drawing to NEWJOB01, NEWJOB02 ,etc.
I can't use wildcards with RENAME command because the old names don't always have a common name.
I prefer to use a lisp routine.
Murtz
Valued Contributor
YankeeSteve
Message 2 of 18 (888 Views)
Re: Batch Rename Blocks
03-03-2008 09:25 AM in reply to: MAD_MONK42
(defun C:BN- ( / blist bl b n)
(setq blist '() bl nil b 0 n "NEWJOB")
(while (setq bl (tblnext "block" (not bl)))
(and (zerop (logand 53 (cdr (assoc 70 bl))))
(not (wcmatch "`**" (setq bl (cdr (assoc 2 bl)))))
(or (member bl blist) (setq blist (cons bl blist)))
(while (and (car blist) (setq b (1+ b)))
(command "_.-rename" "_b" (car blist)
(strcat n (if (< b 10) "0" "") (itoa b)))
(setq blist (cdr blist))
(princ)
MAD_MONK42
Message 3 of 18 (887 Views)
03-03-2008 01:00 PM in reply to: MAD_MONK42
Thanks a lot.
Murtz
Active Contributor
abrusil33
Message 4 of 18 (827 Views)
Batch Rename Blocks - HELP please, Thank you.
02-22-2013 10:57 AM in reply to: YankeeSteve
I would like to rename just a single revision Letter and or option Numbers in the name of multiple blocks
(text string "ZZZ-123-rev.A-object name-option.1-date").
For example, I have 15 blocks in the drawing with names similar to:
  • "blabla-REV.A-blabla-OPTION.1-blabla"
and I need to revise to
  • REV.B and / or (optional) OPTION.2 ("blabla-REV.B-blabla-OPTION.2-blabla"), so I have to
"C:ren", and change one by one, coz wild cards not working if blocks have different characters among *REV.* and *OPTION.*
Would be awesome if it will work like: - > (lisp...) - > type: *REV.A* rename to *REV.B*, and *OPTION.1* to *OPTION.2* for all blocks in the set.
P.S. all blocks has same naming structure: "A-B-rev.A-<name>-option.1-<date>"
<name> - Table 1 , or Table 34, ...(stays unchanged)
<date> - 2011, or 2013 ... (stays unchanged)
*Expert Elite*
Kent1Cooper
Message 5 of 18 (818 Views)
Re: Batch Rename Blocks - HELP please, Thank you.
02-22-2013 01:32 PM in reply to: abrusil33
A few questions:
Would you always want to change both the REV.[letter] and the OPTION.[number] in every Block name?  Or might you at least sometimes want to change only one or the other?
Would something that automatically just increases the letter and the number by one, regardless of their starting values, without User input, be appropriate?  Or would you want the User to specify which letter/number values to change and what to change them to [for instance, if you might sometimes want to change from, say, A to C instead of to B]?
Kent Cooper
*Expert Elite*
pbejse
Message 6 of 18 (803 Views)
02-22-2013 09:19 PM in reply to: abrusil33
Same question as Kent
Active Contributor
abrusil33
Message 7 of 18 (797 Views)
02-22-2013 11:13 PM in reply to: Kent1Cooper
The program "All File Renamer" http://www.altarsoft.com/all_file_renamer.shtml
will rename the portion of any name in all files in this format:
Find: REV.1
Replace with: REV.2
But this program is for windows explorer only.
If there is a LISP that will run Find and Replace in the Block names, that would be awesome.
Any Ideas?
Thanx
*Expert Elite*
pbejse
Message 8 of 18 (790 Views)
02-23-2013 12:28 AM in reply to: abrusil33
abrusil33 wrote:
Any Ideas?
Thanx
Ideas Yes, Need more info though, answer the question at Kent Coopers post, We do not  blindly write a program without knowing all the details. (sometimes we do :smileyhappy: )
*Expert Elite*
pbejse
Message 9 of 18 (774 Views)
02-23-2013 06:35 AM in reply to: pbejse
Find and replace approach
(defun C:BNM- (/ blist bl b find replace FindList Replacelist  NewName)
(defun _match (b l)
       (vl-every '(lambda (k)
          (wcmatch (strcase b) (strcat "*" k "*")))  l
  (setq blist '()
        bl nil
  FindList nil
  Replacelist nil)
  (while  (and
		  (setq find (Strcase (getstring "\nString to Find/Press Enter for none: ")))
		  (not (eq "" find))
		  (setq FindList (cons find FindList))
		  (setq replace (Strcase (getstring (strcat "\nReplace " find " with: "))))
		  (not (eq "" replace))
		  (setq replaceList (cons replace replaceList))
  (and
  FindList
	 (_match (setq bl (cdr (assoc 2 bl))) FindList)
  blist
  (foreach itm blist
    (setq Newname itm)
    (mapcar '(lambda (x y / p)
	(setq p (vl-string-search x (strcase itm))
    	      Newname	(strcat (strcat (substr Newname 1 p) y
    			(substr Newname (+ p (strlen x) 1))))))
	   findlist Replacelist)
    (command "_rename" "_b" itm NewName)
  (print (length blist))(princ " Blocks Renamed")
  (princ)
This demo will look for REV.A and OPTION.1
"A-B-REV.A-Table 2-OPTION.1-2011"
"A-B-REV.A-Table 3-OPTION.1-2012"
"A-B-REV.B-Table 4-OPTION.3-2012"
command:BNM-
String to Find/Press Enter for none: Rev.A
Replace REV.C with: Rev.B
String to Find/Press Enter for none: option.1
Replace OPTION.1 with: Option.2
now if and only if these two items are found on the block name
("OPTION.1" "REV.A")
Only then it will renamed the block with this new values
("OPTION.2" "REV.B")
2  Blocks Renamed
"A-B-REV.B-Table 2-OPTION.2-2011"
"A-B-REV.B-Table 3-OPTION.2-2012"
Now if you only need to find 1 "string match" on the block name, This will look for REV.B regardless of option number
command:BNM-
String to Find/Press Enter for none: Rev.B
Replace REV.C with: Rev.C
3  Blocks Renamed
"A-B-REV.C-Table 2-OPTION.2-2011"
"A-B-REV.C-Table 3-OPTION.2-2012"
"A-B-REV.C-Table 4-OPTION.3-2012"
Another one would be a "Bump" to next value. without prompting for "replace with"
HTH
Active Contributor
abrusil33
Message 10 of 18 (755 Views)
02-23-2013 10:40 PM in reply to: pbejse
THAT IS BRILLIANT. 100% PURE WHAT I NEEDED.
Thank you "pbejse" you are a quiet Expert Elite ++
You are not logged in.
Announcements
Need installation help?
Ask the Community
