Visual LISP, AutoLISP and General Customization
Batch Rename Blocks
26 REPLIES 26
Message 1 of 27
5748 Views, 26 Replies
Batch Rename Blocks
Please excuse if this question has already been posted.
(I couldn't find one exactly)
I would like to batch rename all blocks in a drawing to NEWJOB01, NEWJOB02 ,etc.
I can't use wildcards with RENAME command because the old names don't always have a common name.
I prefer to use a lisp routine.
Murtz
26 REPLIES 26
Message 2 of 27
(defun C:BN- ( / blist bl b n)
(setq blist '() bl nil b 0 n "NEWJOB")
(while (setq bl (tblnext "block" (not bl)))
(and (zerop (logand 53 (cdr (assoc 70 bl))))
(not (wcmatch "`**" (setq bl (cdr (assoc 2 bl)))))
(or (member bl blist) (setq blist (cons bl blist)))
(while (and (car blist) (setq b (1+ b)))
(command "_.-rename" "_b" (car blist)
(strcat n (if (< b 10) "0" "") (itoa b)))
(setq blist (cdr blist))
(princ)
Message 3 of 27
Thanks a lot.
Murtz
Message 4 of 27
I would like to rename just a single revision Letter and or option Numbers in the name of multiple blocks
(text string "ZZZ-123-rev.A-object name-option.1-date").
For example, I have 15 blocks in the drawing with names similar to:
  • "blabla-REV.A-blabla-OPTION.1-blabla"
and I need to revise to
  • REV.B and / or (optional) OPTION.2 ("blabla-REV.B-blabla-OPTION.2-blabla"), so I have to
"C:ren", and change one by one, coz wild cards not working if blocks have different characters among *REV.* and *OPTION.*
Would be awesome if it will work like: - > (lisp...) - > type: *REV.A* rename to *REV.B*, and *OPTION.1* to *OPTION.2* for all blocks in the set.
P.S. all blocks has same naming structure: "A-B-rev.A-<name>-option.1-<date>"
<name> - Table 1 , or Table 34, ...(stays unchanged)
<date> - 2011, or 2013 ... (stays unchanged)
Message 5 of 27
Kent1Cooper
A few questions:
Would you always want to change both the REV.[letter] and the OPTION.[number] in every Block name?  Or might you at least sometimes want to change only one or the other?
Would something that automatically just increases the letter and the number by one, regardless of their starting values, without User input, be appropriate?  Or would you want the User to specify which letter/number values to change and what to change them to [for instance, if you might sometimes want to change from, say, A to C instead of to B]?
Kent Cooper, AIA
Message 6 of 27
pbejse
Same question as Kent
Message 7 of 27
in reply to: Kent1Cooper
The program "All File Renamer" http://www.altarsoft.com/all_file_renamer.shtml
will rename the portion of any name in all files in this format:
Find: REV.1
Replace with: REV.2
But this program is for windows explorer only.
If there is a LISP that will run Find and Replace in the Block names, that would be awesome.
Any Ideas?
Thanx
Message 8 of 27
pbejse
@Anonymous wrote:
Any Ideas?
Thanx
Ideas Yes, Need more info though, answer the question at Kent Coopers post, We do not  blindly write a program without knowing all the details. (sometimes we do 🙂 )
Message 9 of 27
pbejse
in reply to: pbejse
Find and replace approach
(defun C:BNM- (/ blist bl b find replace FindList Replacelist  NewName)
(defun _match (b l)
       (vl-every '(lambda (k)
          (wcmatch (strcase b) (strcat "*" k "*")))  l
  (setq blist '()
        bl nil
  FindList nil
  Replacelist nil)
  (while  (and
		  (setq find (Strcase (getstring "\nString to Find/Press Enter for none: ")))
		  (not (eq "" find))
		  (setq FindList (cons find FindList))
		  (setq replace (Strcase (getstring (strcat "\nReplace " find " with: "))))
		  (not (eq "" replace))
		  (setq replaceList (cons replace replaceList))
  (and
  FindList
	 (_match (setq bl (cdr (assoc 2 bl))) FindList)
  blist
  (foreach itm blist
    (setq Newname itm)
    (mapcar '(lambda (x y / p)
	(setq p (vl-string-search x (strcase itm))
    	      Newname	(strcat (strcat (substr Newname 1 p) y
    			(substr Newname (+ p (strlen x) 1))))))
	   findlist Replacelist)
    (command "_rename" "_b" itm NewName)
  (print (length blist))(princ " Blocks Renamed")
  (princ)
This demo will look for REV.A and OPTION.1
"A-B-REV.A-Table 2-OPTION.1-2011"
"A-B-REV.A-Table 3-OPTION.1-2012"
"A-B-REV.B-Table 4-OPTION.3-2012"
command:BNM-
String to Find/Press Enter for none: Rev.A
Replace REV.C with: Rev.B
String to Find/Press Enter for none: option.1
Replace OPTION.1 with: Option.2
now if and only if these two items are found on the block name
("OPTION.1" "REV.A")
Only then it will renamed the block with this new values
("OPTION.2" "REV.B")
2  Blocks Renamed
"A-B-REV.B-Table 2-OPTION.2-2011"
"A-B-REV.B-Table 3-OPTION.2-2012"
Now if you only need to find 1 "string match" on the block name, This will look for REV.B regardless of option number
command:BNM-
String to Find/Press Enter for none: Rev.B
Replace REV.C with: Rev.C
3  Blocks Renamed
"A-B-REV.C-Table 2-OPTION.2-2011"
"A-B-REV.C-Table 3-OPTION.2-2012"
"A-B-REV.C-Table 4-OPTION.3-2012"
Another one would be a "Bump" to next value. without prompting for "replace with"
HTH
Message 10 of 27
in reply to: pbejse
THAT IS BRILLIANT. 100% PURE WHAT I NEEDED.
Thank you "pbejse" you are a quiet Expert Elite ++
Message 11 of 27
in reply to: pbejse
I can modify code to run: BNM- once if I need to, but normally I have to make sure if both revisions are current, so extra reminder won't hurt.
You guys are genious e s!
Message 12 of 27
pbejse
Good for you, Holler if you need more help.
Smiley Happy
Message 13 of 27
in reply to: pbejse
Guys,
Just figured out that this routine would not work if only 3D blocks in the drawing.
I have to make at least one 2D block within the drawing, and then it will do the rename, as long as I remove 2D block and purge, it is not renaming.  I know it easy for you to fix, but not for me at this time...Thanx
Message 14 of 27
in reply to: pbejse
I am attaching the file as an example that routine would not work as long as associative dimension is in there.
Message 15 of 27
pbejse
My bad abrusil33, error in blist evaluation, nothing to do with associative dimension.
(defun _match (b l)
  (setq blist '()
        bl nil
  FindList nil
  Replacelist nil)
  (while  (and
		  (not (eq "" find))
  (if (and FindList
      (progn
	  ) blist))
	  (foreach itm blist
	    (setq Newname itm)
  (princ)
HTH
Message 16 of 27
in reply to: pbejse
Thanks, works like a charm... !!!!
I appresiate your work, Patrik.
Message 17 of 27
pbejse
Glad it works for you abrusil33
Cheers
Message 18 of 27
in reply to: pbejse
Hi there,
I created OpenDCL form with text input for old rev and new rev
I changed in your routine:
(setq find (Strcase (strcat "rev" "." revN)))  ;;(revN - is a text input from the form - old revision)
(setq replace (Strcase (strcat "rev" "." revNto)))  ;;(revNto - is a text input for new rev. number)
I think option (while (and .... will not work here, I mean it is not working and I am stuck.. I am trying to make the form that will Rev up all the blocks in the drawing by taking two new inputs (1 - for number revision 2- for letter revision)
Thanx  (I spent all my weekend time to figure it out and am afraid I won't ble to fix it on my own)
(defun _match (b l)
(setq blist '()
bl nil
FindList nil
Replacelist nil)
(while (and
(not (eq "" find))
(and
FindList
blist
(foreach itm blist
(setq Newname itm)
(princ)
Message 19 of 27
Netelaana
(princ)
this worked wonders for me - is there a way to modify it to do the same for layer names?
Message 20 of 27
Netelaana
in reply to: Netelaana
....never mind, ran stuck, but then saw my mistake and got it to work. Thanks for starting me out in the right direction!
(defun C:LN- ( / blist bl b n)
(setq blist '() bl nil b 0 n "LAYER")
(while (setq bl (tblnext "layer" (not bl)))
(command "_.-rename" "_la" (car blist)
(princ)
”Boost
