Visual LISP, AutoLISP and General Customization
BREAK LINES HORIZONTALLY OR VERTICALLY
26 REPLIES 26
Message 1 of 27
kameron1967
4247 Views, 26 Replies
Just wondering if anyone can help me with a routine that has the option to break vertical or break horizontal, depending on the option, the lines that cross either the horizontal or vertical (again, depending on the option) a specified distance (say .05) on either side of the line you wanted to keep.  So if I choose BREAKH, the vertical lines that I choose would break any horizontal lines that cross them.  Same applies to BREAKV.  Hopefully I communicated clearly enough.  Thanks in advance!
26 REPLIES 26
Message 21 of 27
kameron1967
in reply to: alanjt_
Thanks, Alanjt_! You guys are awesome! I tested an earlier version and it didn't work. But the one on the link worked like a charm!  Thanks again, everyone!! LOL
Message 22 of 27
alanjt_
in reply to: kameron1967
Glad you got what you needed.
Happy CADing.
Message 23 of 27
pbejse
A mediocre code:
(defun c:bmcut (/ _pts d cutter e pts pts2 p1 p2)
  (defun _pts (ent)
    (mapcar 'cdr (vl-remove-if-not '(lambda (x)
		(member (car x) '(10 11))) ent)))
  (setq d (getdist "\nEnter Gap distance: "))
  (princ "\nSelect Cutter lines:")
  (setq cutter (ssget (setq fl '((-4 . "<OR")
                        (-4 . "<AND")
                        (0 . "LWPOLYLINE")
                        (90 . 2)
                        (-4 . "AND>")
                        (0 . "LINE")
                        (-4 . "OR>")
  (repeat (setq i (sslength cutter))
    (setq e (ssname cutter (setq i (1- i))))
    (setq pts (_pts (entget e)))
    (if (and (setq cut-ee (ssget "_F" pts fl))
             (ssdel e cut-ee)
      (repeat (setq n (sslength cut-ee))
        (Setq en (ssname cut-ee (setq n (1- n))))
        (setq pts2 (_pts (entget en)))
        (setq bpt (inters (Car pts) (cadr pts) (car pts2) (cadr pts2)))
        (setq p1 (polar bpt (angle (car pts2) (cadr pts2)) (* d 0.5)))
        (setq p2 (polar bpt (angle (cadr pts2) (car pts2)) (* d 0.5)))
        (command "_break" en "_non" p1 "_non" p2)
 Only works for LINES and 1 segment polyline though.
Message 24 of 27
kameron1967
in reply to: pbejse
Pbejse - hi. Yes, this one trims horizontal lines around vertical ones. So it's got its usage for BREAKH command.
I then tried selecting only the horizontal lines and voila! - it now trims the vertical lines around the horizontal ones, thus meeting the BREAKV request.  Awesome.  Thank you very much, Pbejse!
Message 25 of 27
pbejse
@kameron1967 wrote:
....Thank you very much, Pbejse!
You are welcome. Glad you found a use for the code kameron1967.
Cheers
Message 26 of 27
kameron1967
in reply to: pbejse
There are 3 different solutions, each with its own merit. I chose yours because it did what I needed it to do. That, however, should not reflect badly on the other solutions because they too have their own function and will offer solution to the limitation that your routine has when dealing with other entities. So I'm greatful for all who stepped up on this. It's one big happy family! Cheers! 🙂
Message 27 of 27
ank_josh
how do i select for vertica lines?
”Boost
