Visual LISP, AutoLISP and General Customization
Avoid VLA-ITEM Error in Conditional
4 REPLIES 4
Shneuph
514 Views, 4 Replies
I just realized I should just be using the tblsearch function but just for curiosity...
I'm trying to see if a text style exists in a drawing using Vlisp.  Thought it would be pretty easy like:
(setq tlv-text_Styles (vla-get-textstyles (vla-get-activedocument (vlax-get-acad-object))))
  (if (not (vla-item
	     tlv-text_Styles
	     "TL-Standard")
	   );not
but if the style name doens't exist it gives an error instead of just nil.  Anyone know a trick to do this sort of conditional statement w/o causing errors?
Thanks.  For now I'll use tblsearch.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
4 REPLIES 4
Kent1Cooper
in reply to: Shneuph
  (if (not (vla-item
	     tlv-text_Styles
	     "TL-Standard")
	   );not
I suspect it's just the way the (vla-item) function is built.  That's where the error occurs:
Command: (vla-item tlv-text_Styles "JONES")
; error: Automation Error. Key not found
Some other functions are similarly picky, and others are not, though I don't know whether there's any identifiable reason for the distinction.  For example, there's that kind of difference between selection sets and lists.  If you ask for an entity name out of a selection set that doesn't exist, you get an error:
Command: (ssname NoSuchSelectionSet 0)
; error: bad argument type: lselsetp nil
whereas you can ask for an item out of a list that doesn't exist, and whether the item or the list doesn't exist, or even if both don't exist, you just get nil, but not an error:
Command: (member NoSuchItem NoSuchList)
nil
or
Command: (car NoSuchList)
nil
That's why if you want to build a selection set by adding things to one with (ssadd), you must start with an empty set first, whereas if you want to build a list, you can use (cons) or (append) to add something to a non-existent list variable name, as a way of starting the list.
You may need to use use some variety of vl-catch-all-... approach, but I'm not up on those [search the Discussion Group and you'll find a bunch of threads about them].
Kent Cooper, AIA
Hallex
I would use something similar on this snippet:
{code}
(if (not (vl-catch-all-error-p
    (vl-catch-all-apply 'vla-item (list tlv-text_Styles "TL-Standard")
  (alert "Style \"TL-Standard\" exist")
  (alert "Style \"TL-Standard\" does not exist")
{code}
See if this helps
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Shneuph
in reply to: Hallex
Thank you both for the replies.  I'll try your snippet when I have a chance, Hallex.  It looks simpler than I was expecting a solution to be.
dgorsman
For VLISP, something returned (even if it is nil) is considered a valid value e.g. found in the collection.  To handle this different way of thinking, it throws an error instead of just returning nil.  In order to deal with that you will probably want to wrap the call in a (vl-catch-all-apply...) function call, which will "catch" the thrown error.  This has an additional benefit, in that (vl-catch-all-error-message...) can tell you exactly *what* the problem was - in this case, whats being looked for is not a member of the collection, in which case you could follow on with adding it.  If the error was more serious (e.g. passing an index value of -1 because of a non-localized variable reset your loop counter) then you could handle that differently.
”Boost
