Hi people,
I'd like to have/write a lisp to change all objects on layer "0" to layer "PC - Module"
If possible also;
Thanks for the help. I am using AUTOcad 2012 without VBA installed.
Solved by _Tharwat. Go to Solution.
Here is my version .... ( without point 3 and 4 )
(defun c:test (/ f l ss i sn e) ;;; Tharwat 31. may. 2012 ;;; (if (and (setq f (tblsearch "LAYER" "PC - Module")) (setq l (not (eq (logand 4 (cdr (assoc 70 (tblnext "LAYER" "0")))) 4) ) ) ) (if (setq ss (ssget "_x" '((8 . "0")))) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i)))) (entmod (subst (cons 8 "PC - Module") (assoc 8 (setq e (entget sn))) e ) ) ) (princ "\n Not found objects on Layer < 0 >") ) (if (not f) (princ "\n Layer < PC - Module >is not found in drawing !!") (princ "\n Layer < 0 > is locked !!!") ) ) (if (and f l) (progn (command "_.qsave") (command "_.close")) ) (princ) )
Thats fantastic! It works well for me, thanks for your help! Now I gotta figure out or if anyone knows how to do the visual lisp part of open next file.
Thanks again!
@mikeyman5000 wrote:Thats fantastic! It works well for me, thanks for your help! Now I gotta figure out or if anyone knows how to do the visual lisp part of open next file.
Thanks again!
You're welcome ,
load the lisp file and add it to the content folder to be able to run the code with every opened drawing .
and after that , Open your drawings ( as much as your Autocad can afford ) and just type the name of the routine in every opened drawing .
This would fasten your works .and good luck
Tharwat
command: 0topc
(defun c:0toPc ( / _Tolayer )
(defun _Tolayer (doc / layers)
(if (tblsearch "Layer" "PC - Module")
(progn
(setq layers (vla-get-layers doc))
(vla-add layers "PC - Module")
(vla-put-lock (vla-item layers "0") :vlax-false)
(vlax-for
layout (vla-get-layouts doc)
(vlax-for
object (vla-get-block layout)
(if (eq (vla-get-layer object)
"0")
(vla-put-layer
object
"PC - Module"))))
(LM:ODBX '_Tolayer nil t)
(princ)
You need the sub LM:ODBX form this website --> Lee Mac Proggraming <---
Then you're on your way to process hundreds of files in minutes.
Holler If you need help putting this together
For an opened draiwng
command: TolayerPC
(defun c:TolayerPC (/ _Process doc layers)
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object))
(defun _Process (lay lays do)
(vla-add lays lay)
(vla-put-lock (vla-item lays "0") :vlax-false)
(vlax-for
layout
(vla-get-layouts do)
(vlax-for
object
(if (eq (vla-get-layer object) "0")
(vla-put-layer object "PC - Module"))))
(if (tblsearch "LAYER" "PC - Module")
(_process "PC - Module" layers doc)
(progn
(princ "\nPC - Module does not exist: ")
(initget 1 "Y N")
(if (eq (getkword "\nCreate Layer [Y/N]: ") "Y")
(_process "PC - Module" layers doc))
(princ)
@pbejse wrote:(if (tblsearch "Layer" "PC - Module")
(progn
(progn
@pbejse , just a clarfication and I could be wrong .
Why you are adding the layer "PC - Moudle" since the search of Layers found it in the layer's Table into your two routines ?
Good catch, at first i was inteding to create layer regardless it the user wants to creat or not, then i change my mind when i read the OPs post again.
So it should be
(vlax-for
layout
(vlax-for
object
(vla-put-layer object lay))))
(cond ((and
(not (initget 1 "Y N"))
(princ)
As for 0topc , that line should not even be there
(progn
(vlax-for
(vlax-for
"0")
(vla-put-layer
object
"PC - Module"))))
(princ)
Unless the OP wants to run the rouitne regardless the layer in question is existing or not
(defun c:0toPcM ( / _Tolayer )
(vlax-for
(vlax-for
"0")
(vla-put-layer
object
"PC - Module"))))
(princ)
thank you for testing the codes tharwat
Cheers
@pbejse wrote:thank you for testing the codes tharwat
Cheers
It is my pleasure .
I think the not function could handle the issue of your first two routines . ( if I am not mistaken )
Best regards.
@_Tharwat wrote:It is my pleasure .
Best regards.
Well NOT really tharwat ,
The TolayerPC (at post #7) is just fine as it includes user interaction and only once that it will ask for creation of new layer.
As for the 0toPc i removed the (vla-add Layers ...) altogether as it is explicity designed to work only if the layer exists
0toPcM doesnt require the tblsearch condition as it will make the layer regardless it exist or not, and it doesnt really "change" the existing layer properties at all if it does exists.
