Is there any AutoCAD variables that tells Autopublish to plot in model space or paper space?
Thank you,
I would like to write a lisp routine to control AutoPublish (Not Publish).
I would like to control AutoPublish pfd Layout or Model space plottinng based upon tilemode.
Thank you,
To Change What Layout Autopublish plots you have to go to options - Plot & Pub Tab - Automatic Publish Button then change the "Include" pull down to what layout you want. I would like to do that all a the command prompt with going through those burried menus. If I had a variable that controlled which layout Autopublish uses then a lisp routine could be make to do all of that at the command prompt.
Any suggestions. Thank you,
