• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Re: AutoLisp and Fields
    11-17-2011 03:43 AM in reply to: angiegauthier
    Can Lisp, or another method, be used to modify Fields in Sheetset etc. I'd like to modify or update dates, text, and revision fields within several large drawing packages which use Sheetsets, is this possible, what would be the best tool / method to use?
    Thanks ! ! !
    Please use plain text.
    10-03-2012 07:32 AM in reply to: putitonpaper
    why is not working?
    (vl-load-com)
    (defun c:Test (/ space ss pt)
    ; Tharwat 14. 06. 2011
    (setq space (vla-get-modelspace
    (vla-get-ActiveDocument (vlax-get-acad-object))
    (if (and (setq ss (car (entsel "\n Select a Dimension : ")))
    (setq pt (getpoint "\n Specify Text Location :"))
    (vla-addMText
    space
    (vlax-3d-point pt)
    4.
    (strcat "%<\\AcObjProp Object(%<\\_ObjId "
    (itoa (vla-get-ObjectID (vlax-ename->vla-object ss)))
    ">%)Area \f "%lu2%pr2%ps[, m²]%ct8[0.0001]">%"
    (princ)
    (princ)
    Thanks!
    Member
    10-08-2012 12:24 AM in reply to: Gustavo_Bernardi
    may be u need to add slash before quotes
    something liske that :
    "%<\AcObjProp Object(%<\_ObjId "
    ">%).Area \f \"%lu2\">%
    10-08-2012 03:04 AM in reply to: Gustavo_Bernardi
    Gustavo_Bernardi wrote:
    why is not working?
    Thanks!
    (strcat
      "%<\\AcObjProp.16.2 Object(%<\\_ObjId "
      ">%).Area \\f \"%lu2%pr2%ps[,m²]\">%"
    HTH
    10-09-2012 03:35 PM in reply to: putitonpaper
    nothing yet ...
    I need to measure the area that is in centimeters and put text in square meters. It would be great if you could put the unit at the end of the text (m2).
    Thanks for now
    10-09-2012 05:59 PM in reply to: Gustavo_Bernardi
    nothing yet ...
    Thanks for now
    Nothing happens? no prompt for text location or no text at all? whats the error?
    sq centimeters to sq meters -- > 15000 = 1.5 ?
    64 bit OS?
    It would help if you'll give us more info.
    10-12-2012 09:24 PM in reply to: putitonpaper
    Hi, yes my OS is 64-bit.
    The object selection is no problem, the base point is then asked me the error that appears is this:
    "Specify Text Location:, error: bad argument type: nil stringp"
    What I did was take the code at the beginning of this topic. So I changed that part of the field by code provided by window creation field with my desired properties.
    Yes, what I need is a measure of area with the value 15000 return me the value 1.5
    Thanks for your patience
    The code works for you?
    (vl-load-com)
    (vla-addMText
    space
    (vlax-3d-point pt)
    4.
    (princ)
    (princ)
    10-12-2012 10:09 PM in reply to: Gustavo_Bernardi
    Try the attached file
    10-17-2012 06:18 AM in reply to: pbejse
    The field works well ... thank you
    Just wish I could control the width of the text box so that the symbol is not in the second row.
    In another lisp that I created, I used the code STRLEN to get the text length (in letters) and multiply by an average width.
    I still have to study these VL-something ... I do not understand any of this, I create my lisps only with get--- and command
    Thank you for your attention
    10-17-2012 08:44 AM in reply to: Gustavo_Bernardi
    You are welcome, I will look into that width thingy tommorrow.
    Cheers
