AutoLISP to "purge" using ObjectDBX is deleting dimensions
2 REPLIES 2
wood.isbell
1519 Views, 2 Replies
I'm working up a routine to simplify clearing some space. I've been cruising here and other places piecing together something, but what I have ended up with is a routine that deletes all of the intended information (possibly needing repetition for those hard-to-reach blocks), but also deletes dimensions from the model space.
There are several things our company does which are "non-standard" but we have been at it for a while and I am trying to work with what I was given. Following is the code. If anyone has an idea why it would be grabbing dimensions and how I could make it stop, I would appreciate it.
;;; not sure who Jeff M is, but assuming this bit is from him
(defun odbx-test (/ dbx_doc)
  ;; edited 5/28/06 by Jeff M
  (if (< (setq dbxver (atof (getvar "ACADVER"))) 15.06)
    (progn (alert
	     "ObjectDBX method not applicable\nin this AutoCAD version"
	   (exit)
	   (princ)
	   (gc)
    (progn
      (if (= (atoi (getvar "ACADVER")) 15)
	(progn
	  (if (not (vl-registry-read
		     "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID"
	    (startapp "regsvr32.exe"
		      (strcat "/s \"" (findfile "axdb15.dll") "\"")
	  (setq	dbx_doc	(vla-getinterfaceobject
			  (vlax-get-acad-object)
			  "ObjectDBX.AxDbDocument"
			(strcat	"ObjectDBX.AxDbDocument."
				(itoa (fix dbxver))
;;; Following bit is compiled from a few places. I know it's messy.
;;; I'll clean it after it works and give better credits (defun C:PURGEDIR (/ fileNames fileName_doc fname folderObject i myDoc obj result sh ) (vl-load-com) (setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application" ) ) (setq Dir (vlax-invoke-method sh 'BrowseForFolder 0 "Browse to the directory you want purged." 512 ; no new folder button "C:\\" ; path start ) ) (vlax-release-object sh) (if Dir (progn (setq folderObject (vlax-get-property Dir 'Self) result (vlax-get-property folderObject 'Path) ) (vlax-release-object Dir) (vlax-release-object folderObject) result ) ) (setq fileNames (vl-directory-files result "*.dwg" 1) filenames (mapcar (function (lambda (x) (strcat result "\\" x) ) ) filenames ) ) (foreach fileName fileNames (if (setq fname (findfile fileName)) (progn (setq fileName_doc (odbx-test)) (vla-Open fileName_doc fname) (repeat 2 (foreach i '("Blocks" ;for some reason the dimensions are being deleted with the Blocks "DimStyles" "Linetypes" "Layers" "TextStyles") (vlax-for Obj (vlax-get fileName_doc i) (if (or (not (vlax-property-available-p Obj 'IsLayout)) (= (vla-get-IsLayout Obj) :vlax-false) ) (vl-catch-all-apply 'vla-Delete (list Obj)) ) ) ) ) (vlax-invoke fileName_doc 'SaveAs fname) (vl-catch-all-apply (function (lambda () (vlax-release-object fileName_doc) ) ) ) (princ (strcat "\n" fname " Purged.")) (setq fileName_doc nil) ) (princ "\nFile not found. It may have been moved or modified." ) ) ) (gc) (princ) )
2 REPLIES 2
pbejse
in reply to: wood.isbell
 or modified."
I cant vouch for the rest of the code
(vlax-for Obj (vlax-get fileName_doc i) (if (and (not (Wcmatch (vla-get-name Obj) "`*D*")) (or (not (vlax-property-available-p Obj 'IsLayout)) (= (vla-get-IsLayout Obj) :vlax-false)) ) (vl-catch-all-apply 'vla-Delete (list Obj)) ) )
 HTH
wood.isbell
in reply to: pbejse
That was the one. Thanks very much. Yes, the rest of the code needs cleaning, but now at least it does not destroy anything unintended. I bet if I make it cycle differently I can get more of the nested blocks cleared, but it will probably take longer.
Either way, this works wonderfully now. I appreciate it.
”Boost
