randy.richardson@york.com (Randy Richardson) wrote in
<685ACA675E262403247E4FF02EFBE752@in.WebX.maYIadrTaRb>:
>Here is a possible work-around:
>If you are reading a file, copy the file to a folder more accessible to
the
>"open" function, read it, and then delete it.
>If you are writing a file, write it in a more accessible location and then
>copy it to the correct location.
>If you are adding to a file...well, you get the idea. If I'm not
mistaken,
>Visual LISP has functions that can copy and delete the files as necessary.
>Anthony Dawe wrote...
>>With users creating directories with long names, it doesn't take long to
>>exceed this 126 character limit. I will probably have to issue a warning
>>about directory name length now!
>>Tony
Randy,
Thanx for the ideas....
They worked fine until the file or directory contains spaces. The VL-FILE-
COPY function fails if the filenames contain spaces (which wasn't a problem
for the OPEN function).
Tony
